Madeouttaglass's custom catback experiment!
Tom brought his 04 Vert with ECS Novi kit down for a tune and when we got it on the rollers we got try a neat experiment. At first glance's Tom's catback looks like a Borla Stinger exhaust but it's actually a stock catback with tips welded on. Then inside his ashtray panel he has remote switch to let the cutouts open-this is the best of both worlds-nice quite cruising, flick the switch and let all hell break loose. It looks like the stock catback is not that restrictive at all?
Cool experiment
FWIW a few tuner shops have posted that they have the Z06 Ti catback on supercharged cars making 700+ all day long with no power issues. With my turbo car however, I did see a pretty big change when I swapped away from the Z06 Ti.
Tony
Tony
I'm just curious if keeping the stock Ti's and going to a 3" h-pipe would suffice for the time being.
I'm really considering a LG Big 3" muffler setup with a 3" h-pipe.
Thanks.
Yep, right around 40-50 to the wheels when I went from Z06 Ti to Borla Stingers. YMMV.
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Nice experiment and the numbers on Tom's car look a little more like they should.
I have picked up a tenth in the quarter with the same experiment so it sounds about right on to me.
Right, that's what my post above said.... the blower tuner shops do 700+hp cars all day with the Ti and no issues, the power gains only become a reality on turbo cars and likely not because of flow capability but because of the WAY the air flows to try to make it quieter. Maybe exhaust gas reversion? Who knows.
Bottom line, Ti is perfectly fine for blower cars from what I've seen and heard.
I knew exhaust and turbo cars go hand in hand, but that makes me justify the cost for a custom exhaust for my car!
That should put me over 600rwhp!!!
Damn, more $$$ to spend!!
Thanks for the info.
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Cool!
I had been contemplating going with something other than my Z06 exhaust but now I think "NOT"
Thanks,Matt
Thanks,Matt
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Doug, I would say that you guys guessed right about my old cam not being right for the blower. Your cam and blower are 100% better than what I came to your shop with last year.
Senior Member
Cruise-In V Veteran
Hey Arun- do you have a video to post? Maybe one with the guy next door coming over to complain about "All dis Godda_ _ noise! Mine ears hurt!"
Senior Member
Cruise-In V Veteran
I have the MSD BAP. It worked fine for my car and goals. Arun was ready to put meth and a bigger pump on and shoot for the stars.
What's your fuel pressure at idle? Under boost how much psi do you lose? I'm at 61 lbs at idle and drop to 57-58 under full boost. I have a stock fuel pump and msd bap.
