NEED HELP/Hard Start
Old May 28, 2008 | 09:13 PM
vegasredz062's Avatar
vegasredz062
St. Jude Donor '08
Originally Posted by ONE BMF
This isn't good -i will post pics of my setup tomm. and maybe someone can tell me if i have a check valve in the brass inline filter--if thats what it is
I have the same problem with my Aps tt, It only does it when its hot..in the winter it NEver did it..I just accepted it as part of the kit..
Im sure it has to do with the Meth kit..
I drove for year and never really had a problem ,, besides the slight hesitation... I just figured its part of the turbo set up
Old May 28, 2008 | 09:18 PM
AlexB333's Avatar
AlexB333
really you just deal with it? I guess I could try to get use to it but I feel like it is causing some damage to the motor starting like that.
I just can't understand why there is not a fix to this! I have called Julio a couple times about this and I feel like I am becoming a pain but I do feel better now because I am not the only one having these problems. I thought it was just me and I was going crazy.
There has to better a better check valve that can be put on that nozzle to hold back the heated up meth from pouring through.
Old May 29, 2008 | 10:09 AM
corvettebob1's Avatar
corvettebob1
I had a long conversation with Julio yesterday and he knows I have been chasing this problem for a couple of years.
So he agreed to do some research for a better check valve, about 2 hours later he called me and told me that he had found some better ones and ordered a few of them.
I agreed to be the guinea pig for the test so he will send me one as soon as they get in.
As soon as I get the new valve I will install it that day and post up the results.
Old May 29, 2008 | 02:31 PM
AlexB333's Avatar
AlexB333
YESSSSS! that is awesome. I will def. be waiting to here the results.
Old May 29, 2008 | 05:19 PM
GOTHAM VETTE's Avatar
GOTHAM VETTE
As I'm just installing my meth kit now, I'm very interested in this!
Old Jun 3, 2008 | 12:37 PM
corvettebob1
Got the new check valve from Julio this morning and installed it.
Just back from a 25 mile drive in 93* heat and the car is sitting out side in the sun heat soaking as I write this.
I will be trying to start it in about 25 minutes.
Old Jun 3, 2008 | 12:51 PM
GOTHAM VETTE
Old Jun 3, 2008 | 01:13 PM
corvettebob1
Sample of 1 test, I'd give it a 9 out of 10.
Old Jun 3, 2008 | 03:38 PM
alzo6's Avatar
alzo6
so far so good bob ?
Old Jun 3, 2008 | 06:16 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Sorry I didn't check in on this thread earlier (didn't know it was alky related) Julio and I have been talking back and forth on this and we think we have the fix for it. He has better access to check the results since he is in FL, we just dont have these issue's in NJ that I know of anyway, but maybe it's not hot enough here.
An easy check would be to simply disconnect your line at the nozzle and place into a clear bottle after the car is hot and let it sit, then you would know 100% whether it is from that or not.
Old Jun 3, 2008 | 10:58 PM
AlexB333's Avatar
AlexB333
Great keep us posted! How do I get in line for these check valves? Should I just call Julio?
Old Jun 4, 2008 | 02:24 PM
corvettebob1
OK, second test.
Did not activate the alky system today drove the car for another 25 miles in 93* heat, let it set for 1/2 hr and on restart it is maybe 9.5.
Spoke with Julio afterwards and one thing he mentioned is there is about a teaspoon of alky between the check valve and the nozzle.
So I will continue to drive it w/o going into boost for a few more times to see if it completely clears up.
Old Jun 4, 2008 | 06:23 PM
  #33
alzo6's Avatar
alzo6
ok Bob, looks like were getting somewhere with this issue. i really thought i was the only one, but thank god for these forums.
Old Jun 4, 2008 | 06:29 PM
  #34
Julio's Avatar
Julio
Another note was the pipe on Bob's car is powder coated steel, not aluminum. Dont know if this also contributes.
Even tho the check valve is on the nozzle itself, past the check valve inside the nozzle is a teeny bit of alcohol. Probably a teaspoon full. If the pipes are hot and this little amount dribbles in.. I can see an issue.. minor and as Bob says 9.5 out of 10 is going in the correct direction. So the next test is moving the nozzle on the pipe itself see if that cures the rest. To get this perfect
To me even if you have a solenoid, the solenoid would have liquid past it.. more so than the check valve.
I got 25 of the higher pressure valves ordered today.
Bob.. keep driving the car and report back..
Old Jun 6, 2008 | 08:28 PM
  #35
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
How is the testing going, it was 92 degrees here today and sure enough every time I let the car sit, I couldn't restart it.
Old Jun 7, 2008 | 12:49 AM
  #36
Julio's Avatar
Julio
Testing is doing great.
call me Monday.. I cant fix things when I dont know who you are
Old Jun 7, 2008 | 04:29 AM
  #37
VetteFish's Avatar
VetteFish
i've noticed it happen on several occasions, but not enough to really worry
