NEED HELP/Hard Start
Old May 24, 2008 | 10:37 PM
alzo6's Avatar
alzo6
Default NEED HELP/Hard Start
i have a ecs paxton setup w/ alky control meth setup and all the sudden im getting an issue when i start the car up after driving for a little or it sits for a while i start it and it idles extremely low almost dies for about 5 seconds then runs fine. almost feels like when you hit the test button on meth and car almost dies. i previously checked the meth to see if its leaking while sitting but it doesnt appear to be that, also wrapped meth hoses as per julio , just in case of heat soak. any suggestions are greatly appreciated thanks
Old May 25, 2008 | 02:23 PM
corvettebob1's Avatar
corvettebob1
Here's what I think is happening, there's a 2-3# check valve in the pump and you have a 1# check valve in the line at the nozzle.
The meth gets hot and expands pushing open the lowest pressure check valve.
When the weather gets cooler it kinda goes away, problem is in Fl. it never completely goes away.
I have disconnected the meth line and plugged the openings and the problem is gone, I have looked for a stronger check valve and no luck.
Even installed 2 in line but it still happens.
Maybe someone else has an answer......
May have to convert to a solenoid.
Old May 25, 2008 | 02:31 PM
Mike04's Avatar
Mike04
I had the same issue. I have the dual nozzle kit, large in line check valve and 1 just prior to each nozzle.
My issues went completly away when I switched to a SD tune. I'm not sure why, might have been something to do with the MAF being close to the nozzles leaking out small amounts of meth as described above.
Good luck tracking the issue down, mine drove me crazy for a good year...
Old May 26, 2008 | 10:45 AM
corvettebob1
We can't be the only people with this issue..........
Old May 26, 2008 | 01:18 PM
alzo6's Avatar
alzo6
i too believe its a heat issue, and the meth is perkulating , so i wrapped all the lines w/ insulation and it seems a little less frequent.
Old May 26, 2008 | 09:00 PM
Mike04's Avatar
Mike04
Here is link to one of my old posts that talk about the issue.
http://forums.corvetteforum.com/show....php?t=1814368
Old May 26, 2008 | 09:51 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
This happen to me the other day, my problem was my cap on the windshield tank, wasn't breathing correctly. My fault I didn't know it was a breather and blocked it off. Try cleaning it properly, see if that is your issue. When your car is running like it's on the test mode, take the cap off the tank and see if that corrects the problem, if it does clean the breather portion and that should fix your issue.
Old May 27, 2008 | 09:54 AM
AlexB333's Avatar
AlexB333
I am really happy I am not the only one having this problem. I can not figure this out and it is driving me crazy. I have had to disconnect my alky because if I don't, after driving it and letting it sit for a little while I can hardly get it to start, thing sounds like a pos in parking lots when I am trying to get it started.
If I disconnect it, no problems. It has to be the heat from the TT setup but I figured that there would be more people having this problem. I just took everything apart this weekend and wrapped the lines. I have not had a chance to try this out yet.
Lets figure this out.
Old May 27, 2008 | 10:19 AM
Sponge Vette
I'm telling you, it sound like vapor lock. Try opening the cap to your tank next time it does it.
Old May 27, 2008 | 10:36 AM
AlexB333's Avatar
AlexB333
So do you mean, run with the cap off? How does opening the cap before I start it going to fix it? I can pull the silicon adaptor off my throttle body after letting it sit for a couple after a hot run and I can see the meth puddled in the intercooler outlet.
I def. have meth leaking past after the fact. My cap is new with the vented hole but I will look at it again.
Old May 27, 2008 | 11:13 AM
corvettebob1
That's a good point, I know on the alky cars with carbs the meth will crystallize in the bowls if it's left sitting in there.
What is the best method to clean that little vent?
Old May 27, 2008 | 11:21 AM
Sponge Vette
Just remove the cap and try spraying a little carburetor cleaner through it, best to drill a couple of pin size holes within that breather for a little better vent.
Old May 27, 2008 | 11:56 AM
corvettebob1
Well we'll see, I just went out and cleaned it. It's the wifes birthday today so we'll be going out to dinner in it tonight.
Old May 27, 2008 | 03:12 PM
AlexB333's Avatar
AlexB333
Can you explain more about this vapor lock theory?
Old May 27, 2008 | 06:19 PM
alzo6's Avatar
alzo6
basically the meth is heating up and causing pressure in the system and while it sits it tends to drip into the intake tube and you get a hard start. same as when gas is vapor locking.
Old May 28, 2008 | 09:42 AM
corvettebob1
Drove it yesterday, about 25 miles and shut it off long enough to have dinner.
Went to start and same ol sh!!
So cleaning the vent did nothing, which makes sense because it's on the wrong side of the pump. (suction side)
I think what is needed is a 3#+ check valve at the nozzle.
That way when the meth expands it will be forced back into the pump instead of the intake tract.
Just a thought but why do we need a check valve in the pump anyway?
The pump is lower the the w/washer tank so it should always have meth all the way past the pump anyway. (cost savings)
Old May 28, 2008 | 11:59 AM
alzo6's Avatar
alzo6
i am insulating the w/w tank today to see if that has any affect on it, i think we need to get julio in on this matter
To NEED HELP/Hard Start
Old May 28, 2008 | 06:28 PM
AlexB333's Avatar
AlexB333
I heat wrapped my line today and just got back from driving it so I will go out in a little while and see how it starts.
I will post back
Old May 28, 2008 | 08:12 PM
AlexB333's Avatar
AlexB333
Yep well I went out and tried to start my car after I let it sit for an hr and same ol crap...barely starts til it clears it out.
I give up. I have tried everything, check valves in the line, on the nozzles, re routed the line 3 times, put heat sleeve on it.
I don't know what else to try!
Old May 28, 2008 | 09:03 PM
ONE BMF's Avatar
ONE BMF
This isn't good -i will post pics of my setup tomm. and maybe someone can tell me if i have a check valve in the brass inline filter--if thats what it is
