Procharger???
Old Jun 11, 2008 | 08:52 AM
427fIc5z06's Avatar
427fIc5z06
Originally Posted by 2003VETT
I was the first novi kit out there. (and the first to put it in the 9's! on a stock bottom) Still going, over 300 passes on the blower alone, over 400+ on the car. Reliability is the key here. This is a fairly basic setup, and still on a 6 rib. It could use an eight, but at that power level, 6 rib is safer! Novi work, and they have been proven, over and over again.
Give ECS a call.
I have a ECS Novi 2000 kit (forged 427) with the eight rib. What did you mean the 6 rib is safer? Should I be concerned?
Old Jun 11, 2008 | 09:31 AM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
I'll get a little belt slip at high boost. Maybe it will hold my stock bottom end a little longer! Dont be concerned. With the 427, you need the 8 rib. I am going to need the 8 rib soon also.
