Heat sleeve for fuel lines
Old 06-13-2008, 07:58 AM
9secz06
9secz06's Avatar
Default Heat sleeve for fuel lines
Anyone know where to get the material sleeve like slp supplies with
there headers. I am looking for that style just larger to do my fuel
lines to help out temps.
Old 06-13-2008, 12:10 PM
9secz06
9secz06's Avatar
I don't know if that is the right terminology or not. Does anyone know
what it is called and where I can find it.
Old 06-13-2008, 12:14 PM
blu00rdstr
blu00rdstr's Avatar
I'm planning to do that also. If you check temp rating of fuel hoses it's usually 200degrees, which is lower than normal underhood or undercar temps. In theory what they're selling for fuel hoses should NOT be used for automotive applications.
The local speed shops (both of them) carry heat protection sleeves. JEGS and Summit probably have it also.
Edit: 'Heat sheild' is the general term, also try searching for the brand 'Thermo Tec'
JEGS http://www.jegs.com/webapp/wcs/store...erm=thermo+tec
Summit http://store.summitracing.com/egnsea...alse&N=700+115
Old 06-13-2008, 12:16 PM
9secz06
9secz06's Avatar
Cool I will check that out. I was going to use it to cover the fuel lines
that I got from Andy because of my exhaust/charge pipes and it is also near one header.
Old 06-13-2008, 01:42 PM
0Brian@FI Performance
Former Vendor
Brian@FI Performance's Avatar
Location: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
Dei 010405
Old 06-13-2008, 04:27 PM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
http://www.keefeperformance.com/
Old 06-13-2008, 08:55 PM
9secz06
9secz06's Avatar
You are the man sir. I found the material on the site. I believe this is
the one.
http://www.keefeperformance.com/aerosleeve.html
Old 06-13-2008, 10:23 PM
Z06Samuel
Z06Samuel's Avatar
Great info on this post!
Sam
Old 06-13-2008, 10:44 PM
ONE BMF
ONE BMF's Avatar
9 sec
Old 06-14-2008, 12:25 AM
9secz06
9secz06's Avatar
Originally Posted by ONE BMF
9 sec
Yeah I know it's a name I can grow into.
Old 06-15-2008, 03:54 AM
blu00rdstr
blu00rdstr's Avatar
So, went out and got a thermal sleeve big enough for three hoses ($30). Looks like one of my Christmas present wrap jobs. Not exactly the look I was going for, I'll just keep the hood closed. I also sprung for the plug wire sleeves ($30/set of four). Those were from Goodies speed shop in San Jose, one of the pricier places to buy parts (but they had them on the shelf).
I would suggest a thermal sleeve for each hose rather than for a bundle. It'll cost more, but it would look better.
Old 06-15-2008, 08:46 AM
BLOWNZO6
Premium Supporting Vendor
BLOWNZO6's Avatar
Personally I think you are wasting your time and money to do this.
I have worked on several dozen cars and have never seen anything to make me believe there is a reason for doing this.
Just my opinion.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old 06-15-2008, 09:40 AM
9secz06
9secz06's Avatar
Well the way I figure it can only help the situation, I don't see where
it will make it worse. I respect your opinion though.
Thanks.
edit:
Maybe I installed it wrong. Should the fuel line be near the longtube or
is there another route?
Old 06-15-2008, 01:27 PM
RED99
RED99's Avatar
http://www.heatshieldproducts.com/index.php
Old 06-15-2008, 02:09 PM
blu00rdstr
blu00rdstr's Avatar
Just my opinion.
This is from one of my two fuel leaks, the other leak was a hairline stream onto the over the axle exhaust pipe.
The stains on the exhaust pipe are from gasoline spraying on it (left side of pic). This pic was taken after I replaced the hose.
Old 06-15-2008, 02:15 PM
blu00rdstr
blu00rdstr's Avatar
There's another route; inside the rocker panels, so from the tank to the drivers' side rocker panel to the drivers' side front fender. The caveat is that anything that crushes the rocker panel can slice the hose open (e.g.; going off the track or road sideways). A metal pipe could serve as armor, and a straight pipe can slide into the rocker panel with the rear tire removed.
Old 06-15-2008, 02:37 PM
BLOWNZO6
BLOWNZO6's Avatar
[img]
[img]
Sorry not sure what the point is... ?
If you want to do it, that is fine, not trying to convince anyone either way... but I have never had to use the stuff. It is not cheap. The only place I use it on the turbo cars is on the starter wires since they are close to the DP, never on the fuel lines.
If you had a fuel line burst due to heat you probably were either too close to the exhaust where you ran the line or did not use the proper line. I have never had an issue with the line I use and I would never use a straight rubber line. EDIT - I see the rubber line you are using... I would never use that for fuel line and I don't use pushlock connectors either.. I use the Earl's ProLine 350 line and the proper connectors for the line.
Like I say.. it is your money, do what you want. I generally don't try to reinvent the wheel. I am more often than not doing this for someone and I don't spend any more of their money (and consequently my time) than is necessary.
To Heat sleeve for fuel lines
Old 06-15-2008, 04:22 PM
blu00rdstr
blu00rdstr's Avatar
The point is that carrying highly flammable liquid through a hose rated below temperatures expected in a passenger car environment is a serious risk. The person accepting that risk is either the company advertising the product as a fuel hose with a 302F rating, or the installer who determines the product is appropriate for the application.
Normal underhood and underbody (air channel shared with cat/exhaust pipe) air temperatures vary from 200F to 300F. Radiated heat and air convection from exhaust manifolds and catalytic converters raise the temperature even higher, especially after shutdown. Cautions for the hose state that when exceeding the max rating, "life expectancy of the hose may be greatly reduced". To mitigate the thermal risk, Aeroquip also recommends 'firesleeve' for hose near high heat: "The use of Firesleeve is recommended for high ambient temperatures, especially near headers or exhaust systems." (Ref: http://www.aeroquip.com/pages/perfor...ical_info.html)
What is advertised as 302F automotive fuel hose, actually has a 200F max rating (page 3):
http://hydraulics.eaton.com/products...Q-MC001-E1.pdf
Old 06-15-2008, 05:13 PM
BLOWNZO6
BLOWNZO6's Avatar
I think that goes to both of our points... using the right material for job.
This is the only type of line I use. Never have had an issue.
http://store.summitracing.com/egnsea...5&autoview=sku
Old 06-16-2008, 07:50 AM
9secz06
9secz06's Avatar
Looking at BLOWNBLUEZ06 thread pictures I did route mine wrong I think.
Quick Reply: Heat sleeve for fuel lines
