too much boost!!!!!!
just got hpt and change the injector value.afr looks good all the why .can not hit WOT because it just started boosting to 12# a@ about 4K.it has been @ 6psi ,like the springs. how could it double?
by the way the motor loved it,it is a stock ls6?bought it used in Florida.it started out in Texas then S.C.,then GA.so who knows what has been done.the boost put me in the seat,felt great!!!!!!!!!
mike in mobile
mike in mobile
mike
mike in mobile
I would talk to Nick Yoskin and pick his brain. Being that its a PTK knock off, maybe he can walk you through some of the issues.
the 6lb. springs are ok,took off gates.i have a turbonetics manual controller.
what is the best way to plum this set up?
please call if you can help me ! mike in mobile
http://s195.photobucket.com/albums/z..._tab_my_albums
this one with WG's back in
The port on the end of the wastegate 'can' be hooked up to a boost controller to provide a way to overboost beyond what the spring is rated for. Giving you the option to go from 5psi (spring rated) to 7, 10, etc using a manual/electronic boost controller. If you aren't running a boost controller then you just let the outside port vent to atmoshpere.
For my kit (your's may be different) I had to tap into the brake booster vacuum line and ran a 1/4" line to the lower port on the wastegate. I was told if I didn't do this, or if that line failed then there would be nothing to force the boost to go out of the wastegate and it would overboost and enter the engine, this may explain your 15#'s.
But, you absolutely must have a line hooked up to the lower port on the wastegate.
If you are using some type of boost controller then you'll have to look up the manual to see how it needs to be installed, but the basic principle shoud be the same.
Upper port = port on the end of the wastegate, furthest from the exhaust piping, sits centered at the end
Lower port = port in the middle of the wastegate, sits closest to the exhaust/manifold pipe.
I AM NOT AN EXPERT... I MAY BE VERY WRONG....
If you are using some type of boost controller then you'll have to look up the manual to see how it needs to be installed, but the basic principle should be the same.
