Finally some dyno numbers!
Old Jun 27, 2008 | 10:07 PM
wildman572's Avatar
wildman572
Default Finally some dyno numbers!
Well guys I finally got my 01 Z06 togather and to the dyno. You guys have been a great help to me and if it wasnt for the forum Its hard to say where Id be with my car. Anyway a short rundown it a 6 speed, stock shortblock. fully cnc ls6 heads flow 298cfm on intake, chambers are 72cc. Custom CamMotion cam, .575 int and 589ex. 226/232 115+2 full tube headers, mid pipe, borla stingers. Ported fast intake, ported ls2 TB. AlkyControl kit, A@A Vortech kit. 60lb inj BAP and lingenfelter pump. I had the power steering resivior hanging lose cause I had to flip my tb upside down to fit. Somehow it ended up rubbing on the damn belt so you know what that means BELT SLIP! He got a pull with belt slipping which was 440hp to the wheels at 5500rpm with 2lbs of boost. What do you guys think this thing will make at 10 to 12 lbs
Old Jun 27, 2008 | 10:18 PM
vettefamily's Avatar
vettefamily
Here is a list of my mods and numbers, with 12 lbs of boost
MTI Low Compression 347 with Lunati Rods, ARP Rod Bolts and Wiseco Pistons
ARP Main Studs
Double Roller Timing Chain Set
ARP Head Studs
Ported LS6 Oil Pump
Billet Steel Flywheel
B&B PRT- TriFlo Catback Stainless Steel Exhaust
LG PRO Headers With Off Road X Pipe
Textrailia OZ700 Clutch with New GM Master and Slave Cylinder
AFR 225 Mongoose Cylinder Heads
ATI D1SC Procharger with Procharger Stage 2 bracket
A&A Corvette Front Mount Intercooler Kit
A&A Corvette Custom Fuel System
ECS Alky-Control Methanol lnjection System
Upgraded T56 Transmission
Autometer Cobalt Boost and Fuel Gauages
B&M Ripper Shifter with Handle
LED taillights
Lowered on Stock Bolts
JL Audio Corvette Stealth Box
JL Audio 10W3-2 Sub
JL Audio 250W monoblock amplifier
Hardwired for passport X-50 8500 radar detector
Optima Red Top Battery
This Z06 made 652 rear wheel horsepower (740 engine HP)
Old Jun 28, 2008 | 08:23 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Well I got 12 PSI of BOOST and at 6350 RPM's I made 639 RWHP (We shut it down early on the dyno )
Thanks,Matt
Old Jun 28, 2008 | 08:27 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Good luck getting your Belt issue fixed and 600+ rwhp should be a walk in the park for your setup
Old Jun 28, 2008 | 10:20 AM
wildman572's Avatar
wildman572
Thanks guys, Im really hoping for 600rwhp. Im going to get the car today, and take it to my body man cause he is anxously waiting for it and then it will be on the way back to the dyno. I will let you guys know what the final dyno numbers end up being. And when the car is done I will post some pics
Old Jun 28, 2008 | 10:36 AM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
I'm guessing 630rwhp.
Old Jun 28, 2008 | 01:45 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
610-630 RWHP
To Finally some dyno numbers!
