Procharger PCV - properly setup??
Iron block 398 w/ d1sc
so far there is about 5k on the mods and I doubt theres a problem with the engine, i pray anyways
I bought the car already built so I dont know if this is setup right but currently it has the lines going:
Ls6 system with the vent on the valley
1. PCV valley vent to a plastic three way tee
2. Line from the Pass side valve cover to the tee
3. Connection from the tee to the air filter
Theres no sources of vaccuum on this setup?!
I was playin around and poped the oil cap while it was running at idle and there is white smoke coming out, wafting pretty much. I dont know how much blowby is normal but it if rev it it goes away..
Should I be going with a catch can setup ala
does your oil seperator/catch can thing have a one way valve in it? if not I'm afraid you're pressurizing your crank case when you go into boost.
whats happening on the driverside valve cover? there is an opening in the back you can include in the system. also, in that pic I don't see anything coming from the air filter like you said.
if that is a check valve in the line coming from the IM, and its installed the right way, you should be pulling good vac when not in boost and getting a good seal when you are. I'd just add the driverside valve cover vent into the system and keep an eye on the oil in that seperator.
Thats not my setup. That was from another car I took that I thought was correct. That is a check valve in there and I thought it was the proper way to hookup a catch can to the pcv system :0 It also has a breather on the driver side.
Here's mine from the iphone, bad quality.
The previous owner did say something about the dipstick poppin out on occassion, but the o-ring was loose, after crimpin the tube I havent had a problem. The driver side just has a cap in the valve cover. In the pic above I just put the breather on to see how it would work, previously it was the normal oil filler cap and I didnt notice any fumes. If I hook the pcv and valve cover line to the vaccuum source where my boost sensor is I get no smoke from the breather so vacccum does help
If i pull the line off from the air filter it pumps quite a bit of air out, I dont know if thats normal.. I am going to hunt down a compression tester and make sure its solid as I am paranoid about this car
I still am a little puzzled with the air filter connection as it wont draw vaccum unless its in the inlet tract or is that where you are saying it has to go, mine is just on the rubber backing part of the filter and it just puffs the air out into that region and gets sucked in from there
I did a compression test when it was cold.. pulled all the plugs, spark and fuel..
150 psi dead even accross all cylinders so unless all of them are bad I guess that much blowby is normal so I will be lookin at doing something to pull the pressure from the crankcase like something above
You want to use the manifold as a vacuum source, not the throttle body port. The throttle body port is in front of the throttle blade, and sees almost constant boost. Cap that off.
Since you have the valley vent, you'd be using that to draw crankcase gases, not the valve cover.
You don't need the driver side breather.
With a breather, you don't really need the line going to the air filter. Yes, it could provide a light vacuum source under boost if the connecting lines were large enough, but what percentage of the time are you under boost?
I don't really like the idea of routing dirty crankcase gases through the intercooler. Let them go out the breather under boost. Would rather keep the inside of the intercooler clean for better heat transfer.
