Any issues with the Vortech?
I have the vortech kit, works great. I had to modify my liquid heat exchangers for better efficiency (switched to two smaller setrab coolers mounted inside the bumper to prevent blockage of the radiator area. The switch provided me about 20% better cooling efficiency at the charge air area as well as no interference with the engine cooling), but that was it. The vortech kit has one downfall, if you plan on higher boost pressures down the road; their pulley setup is not as efficient as the A&A kits or the ECS kits.
I have downsized my blower pulley on my vortech kit one size (2 teeth or approximately 2 lbs. of boost) and have a very slight belt slip issue (the serpintine drive belt not the cogged blower belts) at 5200 rpms. I would imagine if I downsize one more I would slip constantly. he belt configuration could be changed, but it would be a real PITA. Also the other issue with the vortech setup is changing the blower belt. It would be approximately a 3 or 4 hr. job to change the cog belt when the time comes. Other than that, the vortech setup is very pretty looking and the liquid intercooler works very well for a daily driver.
Check out our systems. They are excellent performers and are on sale for $5200 right now.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
This is Allen from San Antonio Texas.
Andy's kit has a FMIC instead of the water to air cooler. His S-trim systems will put out awesome power and also comes with great customer service.
