Hidden nitrous
Old Aug 9, 2008 | 09:16 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Hidden nitrous
Ok, since I am pulling all of this out the car I figured I would show you folks how to hide a nitrous system on a car.
The first step is to hid the stainless steel braided hose, which is the main feed line. It is a good idea to cover it in wire loom.
Then you need a good mounting location to mount the solenoid. I prefer to paint them black so they are harder to see. Then I find a location that is near impossible to find it on the car unless you know where.
When you have a solenoid location picked out you then need to find a good place for the nozzle. In my case I was spraying a dry shot and needed to place it before my mass air sensor(MAF). So I found this great location.
Now in order to make it work you often need some custom work. So I made me a bracket to hold the nozzle abou 6-8 inches from the MAF. I also had a special hose made through some stock fittings to make it look stock.
Now this setup on my car was good for 300 HP. I personally ran a 200 HP dry shot on it.
Old Aug 9, 2008 | 10:27 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Hiding nitrous is no good without teaching them the talk. It goes something like this. " It's stock sept for da mufflers. An I gots dem E3 Diamond sparked plugs and sum dat torco gas stuff I'll race for a hunerd" And don't forget your bubba teeth!
Old Aug 9, 2008 | 10:30 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Sweet! !
Thanks for sharing
Old Aug 9, 2008 | 01:06 PM
samsonxd's Avatar
samsonxd
That is a nice set-up I like what you did I bet there were many faces that looked like after they got beat, where did you hide the bottle though?
Old Aug 9, 2008 | 02:40 PM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
yeah... where did you hide the bottle, in the bumper?
Old Aug 9, 2008 | 02:43 PM
Sigforty's Avatar
Sigforty
The bottle was just in the trunk. In the main well. With a the trunk partition most people never asked for me to pop the trunk. I also ran a FJO controller mounted in the glove box. The progressive ramp never let people suspect nitrous.
Here are some more pics. BeerC5 is he master of switch panels. I had him do me this custom one, and have him working on a new one for my next setup.
Here is the FJO unit mounted in the glove box.
And finally the bottle which sits in the trunk under the covered well. BTW I have a remote opener as well so I never need to visit the bottle except for refills.
Old Aug 9, 2008 | 03:12 PM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
nice... well concealed, but in a money race (the only reason why I can see concealing the setup) I would personally look for a switch panel, or a bottle in the trunk. Well hidden though, there are also some threads on ls1tech about tips and tricks on how to hide nitrous systems.
Old Aug 9, 2008 | 03:15 PM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
So whatcha changing up?
Old Aug 9, 2008 | 03:44 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
A Sneaky Pete bottle in the drivers side front close out panel on the frame-rail with a remote opener is better than the trunk mount...
Someone told me...
Old Aug 9, 2008 | 03:52 PM
ZexZo6's Avatar
ZexZo6
[/QUOTE]
Now this setup on my car was good for 300 HP. I personally ran a 200 HP dry shot on it.[/QUOTE]
A DRY 200 SHOT!!! Holy crap that is pretty risky. How many times have you ran that???
Old Aug 9, 2008 | 04:02 PM
Sigforty's Avatar
Sigforty
I think I am going to a direct port setup. I am still trying to choose what I want to do.
As for the bottle location there are some better places to make some more moves for better hiding. For the money racing down here most people know what they are getting into.
As for the 200 dry it is not that dangerous. I have been running it for about a year now. I have 42 lb injectors and a racetronix fuel setup. The system works great once I had the nozzle placement dialed in.
Old Aug 9, 2008 | 04:11 PM
St. Jude Donor '08
Cool! ECS is getting my car first week in Sept
Staying w/ Nitrous, just upgrading level V tranny, small convertor, and ZO6 rear/hardened shaft, and a Tune. May go up to 150 Dry, same setup 42's Racetronixs pump and a BAP as well.
Old Aug 12, 2008 | 12:48 PM
Sigforty's Avatar
Sigforty
Awesome Beer!! I need to get with you still about my full face switch panel I want to have made. When you get some free time PM me.
Old Aug 12, 2008 | 01:17 PM
St. Jude Donor '08
I get home 28 August hit me up then I can turn it around in a day...Of course I will be at ECS from 2 Sept-4th...
Old Aug 13, 2008 | 09:07 AM
Sigforty's Avatar
Sigforty
Will do, Thanks.
Old Aug 13, 2008 | 09:30 AM
Z06Joe@AutoBuffs's Avatar
0Z06Joe@AutoBuffs
Former Vendor
St. Jude Donor '08-'09-'10
I know a guy who knows a guy.... and that guy hid all his stuff (electronics) in his windshield washer tank..... now that mah friends is stealth!!!!
To Hidden nitrous
