Boosted Motor
I just bought a LS3 (416) from blownz06 (aka Nick Steffens). He has a place in Tennesse. Very easy to work with and gives you straight up answers.
http://www.highpressuremotorsports.com/
14# of boost on a 416 will make around 850RWHP compared to 700RWHP on a 346, plus you gain the extra torque.
For example if you put twin td04 turbos on a 346 and on a 427 they would BOTH max out at about 550whp. The 427 would max it out at a LOWER boost pressure.
Now lets say you put a gt5533 on both cars. Both would EASILY make 1200whp (assuming poper mods and internals) but the larger motor would make it at a lower pressure.
Now lets take this example further. If you put the gt5533 on a 7.0 LS7 and one on a 3.4 2jz. BOTH would max out about 1450-ish whp(ask me how i know). The major difference would be that the Vette would do it probably between 28-32 psi while the supra would need 43-47 psi. The vette would also SPOOL the turbo much quicker and put less stress on the engine due to lower boost levels.
Where the 7.0 would ultimately ovetake the physical capabilities of the 3.4 would be its ABILITY to spool a larger turbo or turbos.
Where the 5533r is about the limit for the supra as far as ability to spool, the LS7 could employ a 101mm or say twin 4294 turbos and push 1700+.
SO..back to the 346 vs. 6.2 LS3. The LS3 is a BIT larger and therefore THORETICALLY able to push/ingest more air but the difference in cubic inches is so small that it would not be noticable, so they would therefor be limited to the output of the turbocharger.
NOW the heads would make a difference, but with the cheaper LS1 the owner could purchase much better heads so it would be a wash.
Hope this makes some semblance of sense
