Supercharged Gas Miles
Old Sep 4, 2008 | 09:46 AM
i2oyal i2ed's Avatar
i2oyal i2ed
12mpg NA...
headers and vararam lol.
Old Sep 4, 2008 | 10:55 AM
ProjecT 9's Avatar
ProjecT 9
I usually get about 275-290 miles to a tank, mixed driving.
All highway I get 320+ miles to a tank.
Old Sep 4, 2008 | 11:06 AM
glennd's Avatar
glennd
I did a milage check to see how close my 72lb/hr @ 3bar injectors were to the advertized value. I drove @ highway speeds 60-80 very light acceleration for a 150 mile trip. The DIC indicated 21.7 mpg. The calculated miles per gallon , based on fuel to refill was 21.5 mpg. This is on an LS3 416" 800 rwhp manual with 3.42:1. Given that the DIC milage is calculated using the injector size for milage, I am very pleased that all the numbers agreed
Old Sep 4, 2008 | 11:23 AM
Mean Gene55's Avatar
Mean Gene55
St. Jude Donor '08
Default Mpg
3.73's & a M6 behind a F1-R'ed 383 ( 752 rwhp @ 14# ) yields me 22-23 mpg highway. Not really concerned with city mpg because I shoot for SMILES per gallon there!!!
Gene
Old Sep 4, 2008 | 02:29 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
ya, I don't use the DIC either. I use the good 'ol fashion way of Fill up vs. Miles driven, and then see what the DIC says also. It's usually off a little... but very little.
Old Sep 4, 2008 | 09:44 PM
vetterlatethannever's Avatar
vetterlatethannever
Averaging 21 MPG with 507/460, this is 55% hwy, 35% city and 10% play , calculated, no DIC for me.........
Old Sep 4, 2008 | 11:18 PM
ProjecT 9's Avatar
ProjecT 9
Isnt the DIC off once you switched to larger injectors? I thought it calculated your mpg based off the stock injector pulse. If your running larger injectors it cant be correct.
Old Sep 5, 2008 | 12:02 AM
glennd's Avatar
glennd
The DIC uses the values in the injector size table, if the new injectors are loaded into the table are correct, then the calculations for fuel milage will be correct. I am using 72 lb/hr corrected to 4 bar pressure, and my indicated DIC milage equals the measured mpg. If you are reading substantially different from indicated on the DIC the chances are you do not have the correct values in the table.
Old Sep 5, 2008 | 07:40 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by felo357
I guess I am getting screw I see 12MPG in the city and 16MPG hwy
540HP 520TRQ
ECS super charger, methanol install by them. I got the stock gears
DTE bracket, suspension, clutch, flywheel tune by ECS I don’t know what r other people talking about but I am the only one whit this numbers what’s wrong I am worried now.
Either you are constantly on it, or you have a failing O2 or something to that effect, you should be much higher than that.
Old Sep 5, 2008 | 07:44 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Originally Posted by 4DRUSH
I get 1 mile per 3 gallons at the track or 3 gallons every 40 seconds
Originally Posted by glennd
You will need 200+ lbs/hr injectors at 100% duty cycle, or a hole in you gas tank
Originally Posted by uniquec5
You beat me to it
Maybe it's just me, but I seam to notice about a 1/16 of a tank drop per all out pass at the track. To go threw a 1/4 tank in a race event is about average to me. (on the 9 second cars, especially big cube stuff)
Old Sep 5, 2008 | 01:02 PM
HIGHRPM's Avatar
HIGHRPM
Originally Posted by AlwaysInBoost
the most accurate way to calculate gas mileage for your FI car is to reset your trip odo at your next fill up. then when it comes time to fill up again take the miles you've driven and divide them by the gallons you just purchased.
using the DIC is not accurate because almost all FI cars have larger injectors or their tabels are scaled differently and that will screw with the stock injector calculations our cars use.
doing the math above I see anywhere between 12-14mpg with a mix of city and highway driving. On the highway best I've seen is a little over 300 miles out of 16 gallons of gas which is about 18mpg. I've never been able to just cruise threw a tank of gas w/o getting into boost at all so I'd guess I could maybe get 20-21mph on the highway if I drove like a *****.
edit: I've got 96# injectors, stock 3.42 rear, stock sized tires & twin fuel pumps...
good thing I didn't buy this puppy for fuel economy!
It takes gas to make HP. I get about 8-10 mpg in town and about 22mpg if I just at cruise at 65-70. Anything other than cruising drops it under 18mpg. Anyone that says they can get 22mpg by jumping on it in town in the low gears is talking pure
Old Sep 5, 2008 | 07:35 PM
glennd's Avatar
glennd
1/16 of a tank = about 1 gallon
800 rwhp = about 1 3/4 gallon per min
a 10 sec run + burnout etc maybe 1/4 of a min. =s about .44 gal.
So using my numbers about .44 gallon per 1/4 mile run. All numbers are aproximate.
Old Sep 6, 2008 | 01:54 AM
  #33
JustinStrife's Avatar
JustinStrife
28-30 @ 75-85
12-17 around town.
Old Sep 6, 2008 | 08:27 AM
  #34
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Before my blower I was averaging 18-19.
After the blower I'm averaging 14-15.
I do drive the car a little harder now.
Its about 25% hwy, 25% city and 50% spirited
Old Sep 6, 2008 | 10:19 AM
  #35
ProjecT 9's Avatar
ProjecT 9
I got 250 miles to a tank my last fill up. (Yesterday)
Old Sep 7, 2008 | 06:57 PM
  #36
wilburn's Avatar
wilburn
could the low gas milage be to a bad tune? I only get around 250 to tank of gas. I tought it was poorly tuned.
Old Sep 8, 2008 | 10:56 AM
  #37
rainman750's Avatar
rainman750
Stock cube, D-1, LG Longtubes, 3.42 Rear, no cats, Borla Stingers, 580rwhp.
29-32 on the highway depending on wether the A/C is on or not and around town forget it......
To Supercharged Gas Miles
Old Sep 11, 2008 | 12:06 PM
  #38
felo357's Avatar
felo357
how do i test my o2 sensors. Would this lower my power meaning the car don’t fell like is pulling hard because air fuel mixture is wrong
Old Sep 11, 2008 | 01:41 PM
  #39
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
I dont pay attention! !
Old Sep 13, 2008 | 07:44 PM
  #40
hermperf1's Avatar
hermperf1
Im getting about 15 around town and maybe 18 on the highway, sometimes down to 12.5 average around town. Compared to the Lingenfelter c5 I had previosly, that got an easy 30 on the highway. But the smiles are there!
