0-5V throttle positon source?
Old Sep 18, 2008 | 12:36 PM
TurboTravis's Avatar
TurboTravis
Default 0-5V throttle positon source?
Guys,
Can I pick up a 0-5V source for throttle position anywhere? My FJO wideband has 2 aux inputs for datalogging, might as well put them to use!
Travis
Old Sep 18, 2008 | 01:49 PM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
on drive by cable stuff (ie not us) the TPS sensor has 3 wires, black with a stripe (gnd), blue (signal 0-5v), and grey (5v constant) I'd think you might get lucky looking at the wiring on the throttle body and see whats up. Of course with an ECM pinout you could trace the wire down there too I bet.
Old Sep 18, 2008 | 02:05 PM
bluewire's Avatar
bluewire
Active Streak: 90 Days
http://forums.corvetteforum.com/show...041&highlight=
This is where I taped mine.
Old Sep 18, 2008 | 06:24 PM
nmp27's Avatar
nmp27
Here is where I took mine from (blue wire)
Old Sep 18, 2008 | 06:38 PM
AVB's Avatar
AVB
TPS, I believe, is frequency based and I don't think the tach is an analog 5v either.
Old Sep 19, 2008 | 01:29 PM
stevieturbo's Avatar
stevieturbo
TPS is a simple 0-5v output.
Old Sep 19, 2008 | 01:32 PM
TurboTravis
Hooked it up last night!
To 0-5V throttle positon source?
