compound turbos?
Old Oct 20, 2008 | 11:31 PM
250racer's Avatar
250racer
Default compound turbos?
i was wondering why you dont see compound turbos being used in the performance car world?... i see them used quite frequently on the diesel side with great success i have a friend with a modded cummins diesel he had a single 67mm turbo and made 45psi of boost and we built a twin turbo setup with the 67 feeding a 75mm s400 on the same truck and have a hard time keeping it under 80psi !!
Old Oct 21, 2008 | 06:25 AM
Warp Factor's Avatar
Warp Factor
Because non-staged turbos will produce as much boost as most gas engines will handle.
When direct injection becomes more widely available on gas engines and is timed to the combustion event (like diesels), maybe that picture will change.
Old Oct 21, 2008 | 07:44 AM
chuntington101's Avatar
chuntington101
as Warp said, you can get all the boost you want from non staged turbos at the moment.
the other idea is sequential trubocharging to help reduce lag...however this is difficult and there are better ideas about....
Chris.
Old Oct 21, 2008 | 07:54 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Direct injection like in the Solstice and Sky??
Old Oct 21, 2008 | 09:35 AM
Rkreigh's Avatar
Rkreigh
diesels can tolerate WAY more cylinder pressure than gas engines. not much need for compound turbos on gas. direct injection is nice, but I don't think it will allow anything but more boost/power and a bit more mileage.
a good twin or single turbo will get us there just fine.
Old Oct 21, 2008 | 11:36 AM
Vince99FRC's Avatar
Vince99FRC
I totally agree. It's not like we can use all the power we create now with our current turbos.
Old Oct 21, 2008 | 05:19 PM
250racer's Avatar
250racer
what about lag i know the compound setup on diesels anyways has way less lag compared to a single.... so why not have a compound setup for lag purposes ?
Old Oct 21, 2008 | 06:29 PM
M_T_0's Avatar
M_T_0
lag on a twin turbo 5.7 or larger c5 ?
More Than Zero
To compound turbos?
