old style a&a bracket???
Old Nov 5, 2008 | 08:53 PM
stangbangin69's Avatar
stangbangin69
Default old style a&a bracket???
is this just the old style a&a bracket or am i missing something. seems like it would have another idler or something. i've searched the forum but i'm not having much luck. please don't flame...
Old Nov 5, 2008 | 09:28 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Mike does have an exyta idler
Old Nov 6, 2008 | 12:39 AM
N4cer's Avatar
N4cer
Yeah man you have a different bracket than I do. One is older but I don't know which one. You're not MISSING anything. It just never was there. I'd also like to know which one is newer.
Old Nov 6, 2008 | 07:22 AM
stangbangin69
i'm pretty sure your bracket is newer than mine.
Old Nov 6, 2008 | 02:11 PM
Brandon619's Avatar
Brandon619
This is correct I have the same bracket as you stangbang. Andy added that extra idler for more belt wrap.
Old Nov 6, 2008 | 02:28 PM
stangbangin69
do you have any issues with belt slippage? what length of belt do you use? i put on a 88 7/8" belt and it seems to fit tight. i do have a problem with it tryin to walk on me a lil i gotta address that issue.
Old Nov 6, 2008 | 03:44 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
You have the same bracket as I do and this winter I am going 8 rib just not sure which way at the moment as I already have all the pulleys
Old Nov 6, 2008 | 04:16 PM
stangbangin69
is there anyway i can modify my bracket so i can mount a third idler on there. i tried with one of the headunit bolts but the pully wont clear. i suppose i could drill and tap some threads and just mount one above the grooved idler right???
Old Nov 6, 2008 | 05:52 PM
Brandon619's Avatar
Brandon619
With my P1 I had no issues at all. Now I'm 8 rib with a F1A and I'm still waiting on a few issue to resolve with fuel pump clearance. You might want to check your alignment of your pulleys and then go from there.
Old Nov 6, 2008 | 05:54 PM
Brandon619's Avatar
Brandon619
I talked to Andy at A&A about this and he said that the next bracket up from ours is a hole new bracket not just idler added. I was thinking the samething of adding a idler.
Old Nov 6, 2008 | 07:13 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
The one you have is the first Generation Bracket of the A&A!
Here is what I have the second Gen Bracket
Hope this helps!
Thanks,Matt
Old Nov 6, 2008 | 08:05 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
I showed Andy the bracket... it's about 4 or 5 years ago... The one we have now is 100 times better...
Old Nov 6, 2008 | 08:13 PM
Brandon619's Avatar
Brandon619
Thats is what I heard but reclocking a F1A is very hard verse a P1 or D1. This is the only reason I have not bought one of your new brackets yet. But I'm sure one day I'll be buying one
Old Nov 6, 2008 | 09:40 PM
stangbangin69
appreciate all the info guys.. looks like i'll have to get a new bracket in the future.. funds won't allow at the moment..
To old style a&a bracket???
