fuel system
Old Nov 7, 2008 | 06:06 PM
69dodgecharger's Avatar
69dodgecharger
Default fuel system
what are you guys using for fuel systems? I plan on running about 550rwhp for now. I was looking at building somthing like the A&A kit but was a little concerned about the pump being turned on and off with a hobbs switch, I mean what happens if the switch stops working?
Is a BAP good enough for 550ish?
Old Nov 7, 2008 | 08:48 PM
Dave concrete's Avatar
Dave concrete
No problem.I running BAP with 60lb injectors 581rwhp don't lose any fuel pressure
Old Nov 8, 2008 | 12:37 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Upto 700+rwhp and 15psi, I was running 60lbs injectors, KB BAP and LPE fuel pump with racetronix harness and Alky Control kit. Zero problems with that setup.
With my new build, I needed more fuel so I went with A&A return style fuel system which is boost referenced. I still kept my LPE fuel pump, KB BAP and Alky kit but I am running a lot more boost now.
HTHs
Old Nov 8, 2008 | 09:55 AM
95vettski's Avatar
95vettski
HTHs
How do you like the A&A fuel system? Did you upgrade the fuel rails as well?
Old Nov 8, 2008 | 10:43 AM
396375's Avatar
396375
St. Jude Donor '08-'09
So you are still running 1 pump?
HTHs
Old Nov 8, 2008 | 10:47 AM
FactoryRaceCar
Stock rails are fine. I will give a complete review once I pick my car up and put some miles on it.
The secondary pump comes on when the car sees boost.
To fuel system
