Nitrous Install Pics
Old Nov 30, 2008 | 06:34 PM
DVS 99's Avatar
DVS 99
Default Nitrous Install Pics
Not finished yet.
Old Nov 30, 2008 | 06:39 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Nice job. what size hit are you starting out with? Did you move your battery to the rear tire well area?
Robert
Old Nov 30, 2008 | 07:01 PM
DVS 99's Avatar
DVS 99
Robert
100 shot for now, And yes, relocated battery to rear.
Old Nov 30, 2008 | 07:12 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Looks great!! Did you use the Lingenfelter relocation kit?
Old Nov 30, 2008 | 07:15 PM
DVS 99's Avatar
DVS 99
Yep! I did. Worked great.
Old Nov 30, 2008 | 11:39 PM
Robert56@RNS
Collections Hold
If you feel like it, please take some pictures and notes on your relocate. I am planning on doing this also, and well, anyone whom has done it already knows the ins and outs. I could return the favour some how, just let me know if you need anything. I do have some questions on how and where for PM if you don't mind.
Robert
Old Dec 1, 2008 | 01:46 AM
DVS 99's Avatar
DVS 99
Robert
I,ll get some pics, it does a very clean install, almost factory clean. Also great for traction.
Old Dec 3, 2008 | 04:46 AM
MAZTIFS_C6's Avatar
MAZTIFS_C6
Maybe I missed it, but what kit are you using? It looks like a very clean install.
Thanks,
Brandon
Old Dec 3, 2008 | 09:03 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Thanks,
Brandon
Looks like the TNT power ring kit. Its the same one I currently run, only I have different solenoids.
Looks good
Old Dec 6, 2008 | 11:12 PM
DVS 99's Avatar
DVS 99
Looks good
Yes, it's a TNT F1 but I need to finish the blow-down tubes. With both bottles connected do I need two? Or can I run just one? Also, I would like to use a Nano system. How does the Nano work with two bottles? Do you need two or one? I think it would look cool if I had one Nano bottle mounted on top. Will I need to change the bottle necks or will the Nano work with the TNT bottle necks?
Old Dec 6, 2008 | 11:33 PM
Corvette-Chris
St. Jude Donor '08
You can probably run a T from both blowdown tubes into one outlet.
For 2 bottles, you will need 2 NANO bottles. I thought about getting another bottle before I got the NANO, but the NANO system allows you to use every bit of nitrous out of the bottle so that close to doubles the amount without the NANO so I opted for the NANO.
Old Dec 6, 2008 | 11:40 PM
Robert56@RNS
Collections Hold
You can use the TNT necks, but will be limited to around a 250 hit. I now have the cheaper 3500series kits also. I am running dual 15lb NANO kits on my NOS bottles, which are good to 350hp. The link in my sig takes you directly to some good NANO info, and about half way down the page is some dual bottle with NANO pics for insight. Let me know if you would like to go on the pre-order notification list as I am having a deal for Vette members this coming week. You could run both blow downs into one line if you like? In the install pictorial on my site is numerous bottle set-ups to get some ideas. let me know if I can help somehow regardless.
Robert
Old Dec 6, 2008 | 11:47 PM
DVS 99's Avatar
DVS 99
Robert
Thanks Robert, Thanks for the help!
Old Dec 7, 2008 | 04:40 PM
Robert56@RNS
Collections Hold
Your welcome. I just thought about your tubes, you can turn them inboard, and drill two ½" holes and let them poke through the deck surface? many do it this way? I haven't, but seems that there must be nothing in the way? Might be option for you?
Robert
To Nitrous Install Pics
