Too much boost and valve float?
Old Dec 3, 2008 | 11:46 PM
95vettski's Avatar
95vettski
Originally Posted by Chris Stewart
Ah, the smackdown gear! How much boost, and were you running meth?
Boost was around 13-14 psi and yes I had meth.
Originally Posted by tlaselva
I dyno'ed my car the same day you did, and you made ~530rwhp.
Stock motor's should easily handle a Novi @ 9lbs of boost and alky.
Did you take out the restrictor plate or go with a smaller pulley, or run out of alky?
I removed the restrictor and had the car tuned. I made another 100 rwhp with a safe air/fuel of 10.9 -11:1. Boost is addictive
Old Dec 4, 2008 | 12:09 AM
FunCool's Avatar
FunCool
You got b@ll's 14lbs of boost on a stock motor!!!!
Old Dec 4, 2008 | 12:13 AM
tlaselva's Avatar
tlaselva
That's what I call testicular fortitude!
Old Dec 4, 2008 | 12:19 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Guys I ran 15lbs of boost on stock bottom for 2+ years making over 700rwhp. I did not baby my car either. There are videos of my car bouncing off of limiter like no tomorrow. I did run Alky, tons of Torco and LS2 timing chain along with all valve train upgrades including hardened pushrods, lifters, oil pump, LS2 chain etc etc...
Stock block was still in perfect condition when it got swapped with forged one. I would just say he had a faulty timing chain
Old Dec 4, 2008 | 12:23 AM
Chris Stewart's Avatar
Chris Stewart
Knowing how 3rd gear instantly took you into high boost, I wonder if the meth never had time to get rolling before it was too late.
Old Dec 4, 2008 | 12:30 AM
FunCool's Avatar
FunCool
Very good point.
Old Dec 4, 2008 | 12:58 AM
LB's Avatar
LB
I don't see what the meth had to do with the timing chain breaking. I believe at 8000 miles it was a factory defect. Just a case of bad luck bobz.
Old Dec 4, 2008 | 06:34 AM
Chris Stewart
Maybe the valve broke from detonation by lack of meth. The motors going 5K rpm and eats the valve. Look at the dent in the piston. The chain broke because the piston didnt?
Old Dec 4, 2008 | 07:53 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I had the same problem with my motor without the broken chain. Just the head of the valve snapped off. Retainer, locks and spring still intact. None of the other pistons had valve marks. I had dual springs on my setup. I spoke with a few engine builders and tuners at the time that said they've seen this happen from time to time and figured it was just fatigue on the hollow valve. I put solid stem valves in my new heads so I don't have this happen again. I was only running 10psi on a forged motor built by Lingenfelter. I don't blame anybody but Murphy.
Old Dec 4, 2008 | 08:56 AM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
No detonation, the plugs would show colour and so would the bearings. The hollow stem valves breaking is a common issue with the LS6 heads. Not too mention the cam sprockets not being tight on the 04 cars.
If it was detonation, the piston would have a been in pieces.
Lot's of people have run and been running over 12-14psi on a stock shorts-remember boost is just a measure of restriction and with stock heads and cam the boost numbers are easy to inflate.
My stock shortblock from 06 is still around doing fine and is going to get blown again very soon. It's all in the tune.
It let go cause it just decided to let go-boost is not the issue. It was probably the end play in the chain-that's why GM put the mounting bosses for GMPP chain dampner on the LS6 blocks.
Old Dec 4, 2008 | 08:57 AM
Former Vendor
Originally Posted by Fun Cool
I want to know if I'm still safe with my power level? My 402ci has a stock single chain in it and I make 740rwt.
You should be fine with your diesel.
Old Dec 4, 2008 | 09:50 AM
AREC5's Avatar
AREC5
I don't think you guys are looking at this the right way, my take on this is that the valves were floating with stock springs then the valve made major contact with the piston. When the valve dropped it got lodged in between the piston and the head hense this is why the piston is all caved in in one spot so the engine tried to stop dead and the stock chain won't take that, hell a double chain wouldn't take it!!!!!!! Good luck with your new build.
Old Dec 4, 2008 | 01:34 PM
  #33
BLOWNBLUEZ06
Old Dec 4, 2008 | 01:39 PM
  #34
BLOWNBLUEZ06
If that's the case, then there would be signs of at least light contact on the other pistons. There is way too much force for a valve, turned sideways in the combustion area with an aluminum piston and cylinder head would even come close to dead stopping an engine. Besides, how does "dead stopping" an engine via smashing a valve between the combustion chamber and piston, which is driven by the crank, put any pressure on the timing chain. Anyone that has hydraulicly locked up a motor would have experienced a timing chain breakage event. That's like saying the tail wags the dog.
Old Dec 4, 2008 | 03:23 PM
  #35
AREC5's Avatar
AREC5
If you read the first post he states all the valves were showing signs of touching the pistons, if the chain broke first then you would have a pile of valves that would be bent major, anyway what do I know? just an obsevation.
Old Dec 4, 2008 | 03:56 PM
  #36
BLOWNBLUEZ06
I can't tell you what you know. Heck, half the time I can't tell you what I know.
I missed the part where all of the pistons were kissed, but where you're losing me was the mention of the motor dead stopping causing the chain to break.
I can understand where stopping the cam from spinning by locking up the valvetrain will cause chain breakage, just not the head of the valve getting smashed between the piston and combustion chamber. That's pressure on the crank, rod, piston, wristpin, combustion chamber and bearings, so I don't understand any way how it would put any additional pressure on the chain. To do that, you would have to have an event that attempts to stop the cam from turning not the crank. That's where the tail wagging the dog comment comes from.
Old Dec 4, 2008 | 06:42 PM
  #37
chriswtx's Avatar
chriswtx
13psi of boost on stock LS6 valve springs= valve float, piston hit valve, hallow valve broke=kaboom...
The 04's came with the newer beefer LS2 timing chains, at least my 04' did so I doubt the chain broke first..
To Too much boost and valve float?
Old Dec 4, 2008 | 07:20 PM
  #38
FunCool's Avatar
FunCool
Try to get this straight, I have a gasoline engine that makes diesel power, it's not that hard to get, really.
Old Dec 5, 2008 | 08:26 PM
  #39
LB's Avatar
LB
Old Dec 5, 2008 | 10:03 PM
  #40
95vettski's Avatar
95vettski
I guess everyone has a different definition of stock bottom ends. No doubt you made great power and it lasted, but your changes are just short of adding forged pistons and rods!
