Too much boost and valve float?
Old Dec 3, 2008 | 09:01 PM
95vettski's Avatar
95vettski
Default Too much boost and valve float?
Last month my motor went kaboom! I pulled all the plugs and the #8 was seriously damaged, the electrode was bent and the plug was banged up. Pulled the valve cover and no broken springs. Fast forward to today and after pulling everything apart this is what was discovered.
Removing the manifold we found the intake valve upstream in the intake runner!
How the heck did that get there?
Removed the passenger side head and you could see most of the valves made contact with the pistons. Pulled the other head off as well with the same reults. This looks like the timing chain has left the building! Sure enough get to the front of the motor and the chain is in the pan!
Here is the #8 piston
Here is the cylinder head.
Good news is the block is fine and will be built with a forged rod and piston.
Who wants to take a stab at what exactly happened?
Old Dec 3, 2008 | 09:14 PM
Rob@ChampionMotors's Avatar
0Rob@ChampionMotors
Former Vendor
Stock valve springs with boost will net lower than the needed spring pressure to avoid valve float.
Old Dec 3, 2008 | 09:33 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It certainly looks like your spring broke as well as the retainers and dropped the valve into the cylinder!
I first thought it might of been a lean condition with the talk of spark plug electrod - But after the carnage shots it sure seems to be faulty springs!
Did the spring crack or is it intact? if intact I would suspect the retainers, that they broke and let loose the valve and then it got spit up into the intake
Thanks,Matt
Old Dec 3, 2008 | 09:36 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
You should see my new valve springs Bobby, good for .700 lift and they drop right in with no machining. I'll need them with my new cam-it has
.650 lift
But seriously if the timing chain is the oil pan, then it probably let go when you made a trip to the rev limiter.
Old Dec 3, 2008 | 09:48 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Looks like the timing chain went and everything got out of time since all of cyliners were banged up.
Old Dec 3, 2008 | 10:11 PM
FunCool's Avatar
FunCool
How much power were you making to snap the chain?
Old Dec 3, 2008 | 10:15 PM
ONE BMF's Avatar
ONE BMF
Old Dec 3, 2008 | 10:23 PM
JBI's Avatar
JBI
Old Dec 3, 2008 | 10:25 PM
95vettski's Avatar
95vettski
Are you saying too much power snapped the chain?
The novi makes mucho power its the stock components that don't agree with that
Old Dec 3, 2008 | 10:30 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I doubt it was too much power. How many miles on the motor ?
The LS motor timing chains are pretty slack and sloppy, what did the chain and gears look like ?
Old Dec 3, 2008 | 10:31 PM
FunCool's Avatar
FunCool
I want to know if I'm still safe with my power level? My 402ci has a stock single chain in it and I make 740rwt.
Old Dec 3, 2008 | 10:47 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
How many miles on the timing chain? LS1 OEM timing chain? Were you bouncing off the limiter when it happened?
Old Dec 3, 2008 | 10:56 PM
95vettski's Avatar
95vettski
8000 miles! Completely stock LS6 motor and no bouncing off the rev limiter. I was 3rd gear at about 4500 rpms and I went wot and at about 5300-5500 rpms the engine went boom! Car shut off and I coasted to the side of the road. I tried to start it and would turn over but not fire. I tried a second time and heard some horrible noises and stopped. Had the car towed home and here we are.
Old Dec 3, 2008 | 10:59 PM
95vettski's Avatar
95vettski
The gears are fine and the chain is together except for one link that pulled apart.
Old Dec 3, 2008 | 11:02 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sounds like a bad chain link. Oh well just in time for hibernation.
Old Dec 3, 2008 | 11:06 PM
FunCool's Avatar
FunCool
I'm never racing you if your starting at 4500 rpms, 2500 or nothing.
5000+ rpms seems low for valve float on a stock motor.
95vettski's Avatar
95vettski
I'm no expert but maybe one the sponsors can jump in with some info for you. When I build up the motor I will definetely go with a double roller chain for sure.
To Too much boost and valve float?
Old Dec 3, 2008 | 11:09 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Got to be careful with double chains that they don't hit the front cover.
I used a Katech Chain in my brothers build.
Old Dec 3, 2008 | 11:25 PM
Chris Stewart's Avatar
Chris Stewart
Ah, the smackdown gear! How much boost, and were you running meth?
Old Dec 3, 2008 | 11:27 PM
tlaselva's Avatar
tlaselva
I dyno'ed my car the same day you did, and you made ~530rwhp.
Stock motor's should easily handle a Novi @ 9lbs of boost and alky.
Did you take out the restrictor plate or go with a smaller pulley, or run out of alky?
