Methanol nozzle location preferences
Old Dec 6, 2008 | 08:09 PM
briann510's Avatar
briann510
Default Methanol nozzle location preferences and trunk or underhood mount?
Does anyone have any worries if you install the nozzle in the rubber coupling boost might leak some at the 2 piece nozzle bung? Ive seen a couple pictures of guys drilling/tapping the throttle body as well and of course having to also drill a hole in the rubber coupling end and clamp which looks like it doesn't leave much clamp width left so could this be a problem for sealing coupling to throttle body with high boost?
I
Old Dec 6, 2008 | 08:15 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I converted mine to a 2-bar and installed it in the intake pipe ( which is longer due to no MAF) where the MAF would be.
I just didn't want you to think no one was reading your post.
Sorry I can't help you more.
Old Dec 6, 2008 | 08:23 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I have mine in a metal ring that goes inside the rubber coupling. Rock steady. No leaks.
Old Dec 6, 2008 | 11:50 PM
highpockets's Avatar
highpockets
Mine are in my BBK alum airbridge.See pic below.
Old Dec 7, 2008 | 11:06 AM
Mike04's Avatar
Mike04
I inserted a piece of tubing inside the coupler to give the nozzles a solid mount. Now I have them mounted in the metal tube close to the intercooler (SD tune).
Old Dec 7, 2008 | 12:46 PM
TRIZ's Avatar
TRIZ
My meth nozzle is installed into the rubber tubing.
I drilled a smaller size hole into the tubing and screwed the nozzle into the tubing for a snug fit (rubber tubing expanded around the nozzle when I screwed it in.)
Sandwiched the tubing between two washers and tightened the nozzle over it.
So far I'm up to 14.5 psi.
Old Dec 7, 2008 | 01:20 PM
glennd's Avatar
glennd
I did the same thing, mounted the nozzles in metal
Old Dec 7, 2008 | 01:52 PM
clemsondave's Avatar
clemsondave
Made a new pipe, had a friend TIG a bung for the meth nozzle. Got a new IAT sensor and split it from the MAF. Meth goes between the MAF and IAT.
Old Dec 7, 2008 | 01:54 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
I used a 90mm TNT nitrous ring (goes on the front of the TB) and plumbed both nozzles into that.
Old Dec 7, 2008 | 06:56 PM
clif's Avatar
clif
St. Jude Donor '09-'10
Here is how I plan on setting mine up. This is from a Z06 I saw last week:
In this setup, the ALKY is sprayed BEFORE the AIT; and AFTER the MAF. This is to provide an extra safety. If the ALKY pump either runs out, or dies, the AIT will sense a sharp rist in air temp, and the PCM will cut back on the timing to save your engine. I love this idea!
Old Dec 7, 2008 | 07:40 PM
Z06PSI's Avatar
Z06PSI
Holy t-bolt clamps Batman.
Old Dec 7, 2008 | 07:49 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I got mine in the Airbridge but my buddy has his in the rubber coupling (After MAF) on his '04 and it works perfect!
I have mine before the IAT sensor and a 2 BAR SD tune, that way the Meth will reduce temps on the sensor!
You cannot spray Methanol through the MAF if you are going to use your MAF! It'll kill it (This is only if you did not already know this )
Thanks,Matt
Old Dec 7, 2008 | 07:57 PM
highpockets
I wish the Alky companies would produce more attractive meth nozzles than the brass one most use,I know its a little detail but it really bugs me to see this under the hood of these very well built cars . Has anyone blown one out of a rubber connecting boot yet ? and just out of curiousity since we are on the subject,are they being mounted in the rubber boots due to convenience or lack of a solid,hard surface mount ? Anyone spraying meth into the intercooler or near the outlet of the intercooler(2 BAR of course) ?
Old Dec 7, 2008 | 08:03 PM
Z06PSI's Avatar
Z06PSI
I am spraying before the intercooler....
Old Dec 7, 2008 | 08:48 PM
highpockets
I should have known one of the KB or maggie guys would catch that,nice !
Old Dec 8, 2008 | 05:57 PM
c5mtl's Avatar
c5mtl
In this setup, the ALKY is sprayed BEFORE the AIT; and AFTER the MAF. This is to provide an extra safety. If the ALKY pump either runs out, or dies, the AIT will sense a sharp rist in air temp, and the PCM will cut back on the timing to save yoru engine. I love this idea!
not sure but dont you think you need a little more space between the meth and the ait.....i remember reading at least a foot
Old Dec 8, 2008 | 07:28 PM
clif's Avatar
clif
I've never read that.... can you find a source of that info?
Old Dec 8, 2008 | 10:23 PM
c5mtl's Avatar
c5mtl
need to search...but makes sense to me ....it seems in the pic the meth nozzle and the iat are really close by....the stream of meth wont have a chance to hit the iat sensor properly....Quote ecs"leave as much room as possible between each componant" maf ,meth ,iat.......i will look for some details later.....some guys even drill and tap the intake just after the tb and install a iat in there and place the meth nozzle in the stream after the maf....personally i relocated my maf to just over the a&a intercooler and the placed my meth and then my iat
To Methanol nozzle location preferences
