ECS BLower Cam Specs
Old Jan 7, 2009 | 10:25 AM
Hvymtlc5's Avatar
Hvymtlc5
Default ECS BLower Cam Specs
Based upon recommendation talked to ECS about a blower cam. They are really reluctant to give out the specs of their "custom designed" cam for my particular application. I guessing because it it it so close to an "off the shelf" like a Comp cam that sells for less $$$.
Anyone run into this before? Want to purchase based on recommendation, but would like to know what I'm getting because I may be able to by a cheaper cam kit if specs are same....with $$ as tight as they are.
Old Jan 7, 2009 | 10:33 AM
4DRUSH's Avatar
4DRUSH
Hows the old saying go, O yea "You Only Get What You Pay For"
Old Jan 7, 2009 | 10:38 AM
thekid96's Avatar
thekid96
ECS and many others don't divulge their cam specs because it takes time and money to develop and perfect those cams and they want to protect their ability to profit from their R&D effort. Pretty straight forward, order a custom ground cam from Comp, or spend the extra $150 and get a cam you know has been developed by the pros.
Old Jan 7, 2009 | 10:42 AM
Blue Lightening's Avatar
Blue Lightening
If you were sitting in ECS's shoes would you give out that information for others to copy? I have their blower cam and am quite pleased with it expecially at top end.
Old Jan 7, 2009 | 11:37 AM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
Just go with something custom ground for your setup.
I would only go with theirs if they were doing the install/tune.
Old Jan 7, 2009 | 11:40 AM
Hvymtlc5's Avatar
Hvymtlc5
Understand the business side.
I guess real issue is my builder does not know what were putting in there, he has his own ideas fora cam profile based on my options...AND I don't like th idea of buying something first before I can actually find out what I'm buying. Thanks for you opinions, ECS must be good
Old Jan 7, 2009 | 12:54 PM
chriswtx's Avatar
chriswtx
What are you building??specs on the motor?? What kind of idle/driveability do you want? Maybe we can point you in the right direction with what has worked for us..
Old Jan 7, 2009 | 01:24 PM
Hvymtlc5's Avatar
Hvymtlc5
I had asked (provided info on motor) in previous and got an overwhelming response to use Chris's cam at ECS. So I decided o go that route until I coulnd't get any info. Again like I said above if they are as good as the forum says they are may I don't need to know what I'm getting....
Old Jan 7, 2009 | 01:30 PM
vetterlatethannever's Avatar
vetterlatethannever
I have their blower cam and don't know the specs. All I know is the power it makes is very good (HP and TQ) and there are some ugly fast cars on this Forum running them.
Old Jan 7, 2009 | 01:43 PM
4DRUSH's Avatar
4DRUSH
No Soup For You!!!!!!! Next
Old Jan 7, 2009 | 02:48 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
I can assure you thats not the reason. We sell all our own custom cams for $419.. I would venture to guess if you call comp the price will be in the $400 range, possibly more.
We dont give out exact specs but we tell everyone the same thing. The duration is in the 220's and lift is well below the 600 mark. The cam drives like stock and makes tons of power. We understand that some people might not want to buy it because we are secretive with the specs and we are to a certain point. The bottom line it thats its the most streetable cam and makes the most power. We have many cars running in the 9's to back this up.. Listen to some of the idle clips on line as well and you will see how docile it it. Hope this helps clear things up..
Old Jan 7, 2009 | 03:17 PM
slowtealz28's Avatar
slowtealz28
Chris, did you guys ever dyno a car with your blower cam, then with a 224/230 on a 114? If so, what were the resuluts???
Dave
Old Jan 7, 2009 | 03:18 PM
Hvymtlc5's Avatar
Hvymtlc5
Chris of course you're correct on the Comp pricing. Thanks for answering up and providing more detail - we'll talk more
Old Jan 7, 2009 | 04:02 PM
slothy's Avatar
slothy
also epp's blower cam
Old Jan 7, 2009 | 04:41 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I have ECS blower cam for my 99% street car that has also ran 10s on the track with street tires. It is very stealthy. I would do it again in a heartbeat.
Do a search over You Tube and you can find my car with this cam idling etc
Old Jan 7, 2009 | 09:18 PM
Hvymtlc5's Avatar
Hvymtlc5
Chris - video links have been removed
Old Jan 7, 2009 | 09:47 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
IMHO cams should not be bought off of a name, part number, or popularity.
The cam chosen should be based off of your EXACT specs. Motor size, compression, gears, tranny, driving style, head size, head flow, type of power adder, and overall way of how you want it to run, should determine what you buy.
Just because Nike Air Jordans are the best basketball shoe, doesnt mean everyone buys the same size as Michael Jordan wears...
Cams are tooooo important to buy based off of a trademarked name..
That being said, I do not feel ECS should ever give up their specs. They race wayyyy to much, spent a fortune in testing, and have wayyy to many people trying to copy what they do.. $419.00 is an awesome price.
To ECS BLower Cam Specs
Old Jan 7, 2009 | 10:15 PM
vrybad's Avatar
vrybad
Chris,
At some point I am going to do a cam.
Still all stock LS6 with TT.
Would your cam work well in my application with the TT's?
Thanks for any help.
Old Jan 8, 2009 | 12:21 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Personally, I would never run a cam without first matching the specs specifically to my engine/set-up and intended use!
Old Jan 8, 2009 | 01:06 PM
DOUG @ ECS's Avatar
DOUG @ ECS
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by vrybad
Chris,
We have a different cam for your build, give us a buzz when your ready.
Guys,
some people do not like that we do not indulge our cam specs, but at the end of the day our blower cams are one of, if not the, most proven set ups on this board. Sorry if we will not give away years of testing so it can be copied, especially since we sell the cams for basically the same price as if you called Comp for an off the shelf cam.
