Boost by Gear with Auto boost controller?
Old Mar 6, 2009 | 05:54 AM
Rkreigh's Avatar
Rkreigh
Default Boost by Gear with Auto boost controller?
need some help. wanting to interface the boost controller with the PCM or find something that will allow controlling boost by gear.
is there some way to do a paddle shifter that could interface?
if I can ramp up the boost by gear, I'm sure the car would be much faster and hook better.
spring is coming FYI, car is a built 346, TTiX, 800 rwhp, RPM stg 5 a4 with a 3200 multi disk convertor
thanks for any advice!
Old Mar 6, 2009 | 06:52 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
This is way out of my league!
I've thought about a B@@ST controller for my ProCharger too - it's a thought and I like your idea just don't if it'll interface with the PCM!
But I am interested to see some responses
Thanks,Matt
Old Mar 6, 2009 | 08:51 AM
Slow Z06's Avatar
Slow Z06
What BC are you using? The Eboost2 is sayining it can do that. I thinks APEXI has one out you can do it with. ( boost by gear that is )
Old Mar 6, 2009 | 10:21 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Boost by speed, picking up the speed from one of the front wheel sensors will probably be the easiest way to control boost and prevent overboosting from spinning.
Old Mar 6, 2009 | 10:47 AM
Slow Z06's Avatar
Slow Z06
Now that idea I like. Ill need to check into that one
Old Mar 9, 2009 | 06:28 AM
Rkreigh's Avatar
Rkreigh
some of the boost controllers can do it with a manual by using micro switches on the tranny, I've got an automatic.
looking to interface with the PCM or potentially boost by speed could work too. thanks for the help!
To Boost by Gear with Auto boost controller?
