PCV Routing Help
Old Mar 22, 2009 | 02:24 PM
Slow Z06's Avatar
Slow Z06
Default PCV Routing Help
Tried searching on 5 different forums so don't tell me to use the search.
Need simple ( BIG ) pictures of how to route this. I have twin turbos and 1 catch can. Also, Since there is only 1 vacuum source on the front of the engine, where is everyone mounting:
Boost line
waste gate sources
blow off valve sources
Hobbs switch
Currently I have the waste gates run to where the PCV was and the blow off valve run into that T. I have ran the Hobbs switch t'd into the waste gate as well.
Help please. Internet stupid today
Old Mar 22, 2009 | 02:55 PM
user_name's Avatar
user_name
Sorry. I had to. =) Honestly, you could just run a breather though.
Old Mar 22, 2009 | 04:04 PM
Slow Z06's Avatar
Slow Z06
LOL
NOSIR, cant stand the oil getting dumped in the intake
Old Mar 23, 2009 | 05:59 AM
Warp Factor's Avatar
Warp Factor
What's common is to cut the brake booster line and insert a fitting with multiple small hose barbs for boost gauge, waste gate, blow off valve, Hobbs switch.
The PCV system can be run normally with the catch can inserted before the manifold, except that you need a supply air source (the normal supply from the throttle body must be capped) and possibly a check valve to keep manifold pressure from back-flowing to the crankcase under boost. Depending on which PCV valve you have, it may work fine as a check valve.
A well-baffled valve cover breather works well as the new make-up air source, and will also vent crankcase pressure under boost when the PCV isn't working. Some people run a hose to the air cleaner instead, but this may not have enough flow to adequately relieve pressure when it back-flows under boost, and I don't like the idea of routing dirty crankcase vapors through the intercooler.
Old Mar 23, 2009 | 11:18 AM
Slow Z06's Avatar
Slow Z06
Thanks guys. Got it taken care of
To PCV Routing Help
