Blower cam selection
Old Mar 23, 2009 | 11:58 PM
jjnitrox's Avatar
jjnitrox
Default Blower cam selection
Hi:
I bought a procharger supercharger stage II kit. It is going to be installed on a 00 vette. It has 1 3/4 LTs
3" pipes, magnaflow mufflers and a 160 thermostat. Besides custom tunning and TR6 spark plugs I would like to put a cam with springs and pushrods.
1)What cam do you guys suggest? (I was thinking using a 224-230 @.50 with a ls of 114)
2) what size of injectors you suggest? (I was thinking 60 #ers)
3) What fuel pump would you suggest?(I have no idea what to use) Any suggestions are welcome. Thanks
I forgot to mention is a M6 and has a LS6 intake,bored and polished stock Throttle body and modified mass air flow.
Old Mar 24, 2009 | 01:57 AM
whitebullet7's Avatar
whitebullet7
my cam is 228/232 575/595 114lsa,my car made 655/565 at 10psi with a p2sc-1,racetronix fuel pump and 60lbs injectors.the car been to the track couple time and i drive it almost everyday
Old Mar 24, 2009 | 06:55 AM
breecher_7's Avatar
breecher_7
I have a cam that would suit your combo well, its only got 2K miles on it, if your interested send me a PM.
As far as the other stuff....
60#'ers will be just fine for injectors.
For fuel I would look into a full fuel system upgrade as then there will be nothing standing in your way of even more power. Contact Will over at RSI, he will hook you up with what ive found to be the best fuel system available for these cars.
Old Mar 24, 2009 | 10:44 AM
03blackZ06's Avatar
03blackZ06
a boost a pump will owrk 60 lb injectors and that cam sounds good. i have a 224/232 114 i make 650 rwhp and 585 rwtq thats with meth also. 9lbs of boost.
Old Mar 24, 2009 | 11:12 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
We might be a bit bias but we feel we make the best blower cam. Its the most streetable, makes the best dyno numbers and holds the record for the fastest C5 and C6 LS2 corvette..
Old Mar 24, 2009 | 02:42 PM
Streetfast's Avatar
Streetfast
ECS record speaks for itself.
Old Mar 24, 2009 | 03:00 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I cannot say enough good things about ECS's cam. Proven!
Old Mar 24, 2009 | 03:43 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Just picked up one these cams for my (LS3 - 416).
Old Mar 24, 2009 | 04:35 PM
jjnitrox's Avatar
jjnitrox
Hi Guys:
Thanks for all the feedback and suggestions greatly appreciated.
JJ
Old Mar 24, 2009 | 06:35 PM
CYA-Vett's Avatar
CYA-Vett
No doubt about it. This is the cam I run and I couldn't get my car to run slow enought in a 10.5 bracket, I broke out twice. I guess I move to 10.0 next time.
Great cam, great service and best of all, great people.
Disclaimer: If you don't want to run 9.80's with a stock bottom end, this cam is not for you
Old Mar 24, 2009 | 06:59 PM
JET LEE's Avatar
JET LEE
Which procharger do you have? P1SC or D1SC?
I ran MTI's R1 cam. It worked great on my stock LS6 engine. It was a 232/236 .575/.578 114.
I also ran 60lb injectors and the racetronix fuel pump and harness.
With my 1 7/8 ARH and 3" x-pipe and 5.5 psi boost, I made 595/508 at the wheels.
Old Mar 24, 2009 | 07:09 PM
FactoryRaceCar
Which cam would you consider to be better than ours? Our cam idles very very well and has great street manors..
Our blower cam went 9.19 in a C5.. How fast did the cam you were speaking about go?.. Here is an idle clip from our cam...
http://www.youtube.com/watch?v=Vh9zlwsWH80
That car looks familiar
How about this one with the cold idle and the same car
http://www.youtube.com/watch?v=YOFE7-qHD5Q
Old Mar 24, 2009 | 07:14 PM
95vettski's Avatar
95vettski
Does anyone know what lobes this cam is ground on, xer ,xe?
Old Mar 24, 2009 | 07:18 PM
breecher_7's Avatar
breecher_7
Not everyone who makes big power drag races...
Old Mar 24, 2009 | 09:06 PM
FactoryRaceCar
Yeah but fast on track is fast on street. No arguements there! I don't drag race myself.
Old Mar 24, 2009 | 09:17 PM
breecher_7's Avatar
breecher_7
Fast on road course is fast on street...
Old Mar 24, 2009 | 09:25 PM
FactoryRaceCar
F/I on roadcourse in our cars is a disaster
To Blower cam selection
Old Mar 24, 2009 | 09:37 PM
breecher_7's Avatar
breecher_7
No, its a hell of alot of fun!!!
Not to mention that in order to run 9.1 you don't just need a cam...
Im assuming that car went a little more like this: powerglide or very nasty auto of some sort, 4.10 gears, 28" slicks, lightweight drag brakes, AC removal, interior removal, air bag removal, sway bar removal, etc, etc, etc.....
Now how many "real" cars have gone that fast with "just" that cam? Saying a car went 9.1 with it isnt saying much when the rest of the car is a straight up purpose built drag car.
As I said earlier, there are alot of other factors, that cam is not for everyone.... And it is a very good cam for the record.
Old Mar 24, 2009 | 10:32 PM
FactoryRaceCar
I went 10.8 with 100% street car (everything you mentioned above in place with full audio subwoofer etc) with that cam with 19" Nitto Invo tires spinning half way down the track before getting kicked off the track. You probably don't know much about my old car. It was built for one thing only in mind. A total street car. I don't drag race.
That cam REALLY works.
Old Mar 24, 2009 | 10:35 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In V Veteran
Originally Posted by Blue Lightening
I have their blower cam and am quite pleased with it expecially at top end.
Originally Posted by vetterlatethannever
I have their blower cam and don't know the specs. All I know is the power it makes is very good (HP and TQ) and there are some ugly fast cars on this Forum running them.
I have ECS blower cam for my 99% street car that has also ran 10s on the track with street tires. It is very stealthy. I would do it again in a heartbeat.
Originally Posted by Yellow03Z06
and with 100 octane and no restrictor plate.
Great cam and great SC kit. Combined with a great tune, you can't go wrong. Who cares what the exact specs are?
Originally Posted by 95BlueBomber
All I know is the following....
I took my car to the dyno in BG and on low boost and no meth I broke the 600rwhp mark on a stingy dyno. The owner of the shop had a car in there that had tested 6 or 7 cams in his car and couldnt make power. I gave him ECS' number and told them to order the blower cam. In the words of Emeril... BAM! 76RWHP
All I know is the cam drives awesome, makes power, gets good gas mileage, and the people who sold it to me have never refused to help me on any of my projects.
Originally Posted by My first GTO
We had the Small ECS cam in the car, Now WE have Moved Up to The Big ECS Blower cam and I still Don't know the Specs or Care about them. All I know is The Crew at ECS has NEVER Been Wrong with My set Up......Frank
Originally Posted by EG@EnglandGreen
But even though we have our own line of blower friendly cams, we ALWAYS recommend to our customers to get the ECS blower cams if they are looking for maximum FI power and stock like idle and street manners.
Doug and Chris have many mid 9 second Vettes running their cams - and that's good enough for us.
Stephen
I can name more, but search must be broken again.
And as far as real cars going fast with this cam, I was with one on sunday at the roadcourse - infact it's not all that different of a build than 4d's car (sans the trans), and yeah, he was fast, with over 700hp at the tire. He ran both Saturday and Sunday.
I might have some video if you'd like to see that too.
