Re tune
Old Apr 1, 2009 | 01:36 PM
sultan 2 ZR1 KSA's Avatar
sultan 2 ZR1 KSA
Default Re tune
hi guys i just installd a set of paitior 660 lift springs on my car do i need to re tune it again ????
thanks
Old Apr 1, 2009 | 01:41 PM
chaase's Avatar
chaase
St. Jude Donor '12
I wouldn't bother.
Old Apr 1, 2009 | 01:48 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
If you're trying to get the absolute most out of your car, it might be worth a review.
Old Apr 1, 2009 | 01:50 PM
sultan 2 ZR1 KSA
thanks for the reply my frind
may i take another openion ?
Old Apr 1, 2009 | 02:59 PM
user_name's Avatar
user_name
Most likely not needed. I wouldn't heard to do a quick scan to verify though.
Old Apr 1, 2009 | 04:15 PM
Slow Z06's Avatar
Slow Z06
not needed unless you are planning on reving higher than previously.
Old Apr 2, 2009 | 06:17 AM
EPP's Avatar
0EPP
Former Vendor
thanks
I don't see a need for a retune unless your engine was breaking up in the upper rpm range and the tune couldn't be dialed in. Bob
Old Apr 2, 2009 | 06:54 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
thanks
I don't believe it would be necessary to have a re-tune!
"BUT" it also wouldn't hurt to have it looked at and perhaps cleaned up with a couple of adjustment - due to the stronger springs
A re-tune is usually less depending on the tuner
Thanks,Matt
Old Apr 2, 2009 | 09:00 AM
sultan 2 ZR1 KSA
thanks guys for your input , i guss i will be heading to the dyno saturday , wish me luck
Old Apr 6, 2009 | 03:06 PM
Jason Blue Boost's Avatar
Jason Blue Boost
Any results from the dyno with the bigger turbo's?
Old Apr 6, 2009 | 04:17 PM
a1231212's Avatar
a1231212
To Re tune
