Meth users where do put you IAT sensor
Old Apr 27, 2009 | 12:46 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Default Meth users where do put you IAT sensor
I've been thinking about relocation the IAT sensor so my tuner can do big time timing retard if the meth pump stops spraying. Where did you guys relocate it to?
Old Apr 27, 2009 | 12:51 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
http://www.dallasperformance.com/DPC...Alky/index.htm
bullitt4110's Avatar
bullitt4110
I put mine right before the TB in the intake tube.
Old Apr 27, 2009 | 12:54 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Originally Posted by Corvette-Chris
I saw your picture but I am afraid putting into the coupler it will pull out under boost. My meth nozzle screwed into the t/b side of the maf sensor which seems to working fine. Has anyone put it on the intake manifold?
Old Apr 27, 2009 | 01:25 PM
slothy's Avatar
slothy
CHECK FI section i think LB did right behind throttle body.
edit: nm this is in the fi section lol
Old Apr 28, 2009 | 12:35 PM
c5mtl's Avatar
c5mtl
i drilled into the intake right behind th tb ...used some melted abs to bond everthing works great
Old Apr 28, 2009 | 01:04 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
any pics of that. That was I was thinking about doing.
Old Apr 28, 2009 | 02:55 PM
FreddyG's Avatar
FreddyG
You could put a piece of stainless sheet metal inside the coupling that's the same diameter and drill into that. It wouldn't effect anything and it would give the IAT sensor something to bite into.
Just a thought.
Good Luck!
Old Apr 29, 2009 | 01:38 AM
c5mtl's Avatar
c5mtl
http://forums.corvetteforum.com/c5-f...at-sensor.html
Old Apr 29, 2009 | 06:33 AM
miami993c297's Avatar
miami993c297
Scroll down for the post for the Relocated IAT Sensor pics:
http://forums.corvetteforum.com/1558726934-post26.html
Christian
Old May 27, 2009 | 07:22 PM
D C's Avatar
D C
USMC (retired)
Reid are you going to do this? I am planning on doing this prior to the speed density tune so that the reading is accurate.
Old May 27, 2009 | 08:21 PM
NemesisC5's Avatar
NemesisC5
Old May 27, 2009 | 08:54 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Here's mine on the LS2 intake.
Old May 28, 2009 | 07:35 AM
MYLS6's Avatar
MYLS6
Here is mine--- looking at yours wondering if I need or should relocate...hmmm
To Meth users where do put you IAT sensor
