Post up stock cube numbers!
Old May 6, 2009 | 09:51 PM
NemesisC5's Avatar
NemesisC5
Old May 6, 2009 | 09:54 PM
HP_Addict's Avatar
HP_Addict
Power: 754 rwhp/594 rwtq
Compression: 9.5:1
Power Adder: ECS Paxton Novi 2000
Boost: 16
Fuel: 93 + Meth
Timing: ?
Bottom end: Forged
TRIZ's Avatar
TRIZ
Old May 6, 2009 | 09:56 PM
user_name's Avatar
user_name
Originally Posted by NemesisC5
Power: 708/640 @ the wheels
Compression: 10:1
Power Adder: A&A V2 S-Trim
Boost: 11.4 psi
Fuel: Shell 93/Torco/Meth
Timing: 21*
Bottom end: Stock
*** With 100k mile warranty
Take note of the tq numbers on this 346! Seriously impressive.
Old May 6, 2009 | 10:00 PM
95BlueBomber's Avatar
95BlueBomber
641rwhp 536rwtq
Old May 6, 2009 | 10:12 PM
FRC Joe's Avatar
FRC Joe
Power: 617rwhp/536rwtq, traps high 134s
Compression: 9.6:1 (6.0 heads)
Power Adder: T-Trim, A&A kit, 3.5" pulley, 6 rib
Boost: 10psi @ 6200
Fuel: 93 Octane + Meth
Timing: 17*
Stock bottom end
Old May 6, 2009 | 10:34 PM
Streetfast's Avatar
Streetfast
Scotty you sure they didn't put in a 427 by mistake. Those are great number on stock bottom end and a S-Trim.
Compression: 10:1
Boost: 11.4 psi
Timing: 21*
Bottom end: Stock
Old May 6, 2009 | 10:45 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
http://www.aacorvette.com/gallery/di...album=50&pos=3
Old May 7, 2009 | 02:10 AM
texada's Avatar
texada
Originally Posted by CYA-Vett
Who cares about dyno sheets....Is this a Mustang forum?
9.80 @ 142
Novi 2000
Meth kit
Cam
Stock Heads
Stock exhaust
Stock bottom end
Stock rear
What Cam with stock manifolds? How much Boost?
What fuel system?
Old May 7, 2009 | 08:11 AM
NemesisC5's Avatar
NemesisC5
Thanks Joe
Thanks Lee, sometimes the combination just exceeds expectations...and a lotta luck helps keep it together
Old May 7, 2009 | 11:14 AM
HotRod68Camaro's Avatar
HotRod68Camaro
Power: Current:613hp/540tq Prior:700hp/570tq
Compression: Stock
Power Adder: F1C
Boost: Current: 6lbs Prior: +11lbs
Fuel: 93 + Meth
Timing: high teens
Bottom end: Stock
Old May 7, 2009 | 03:10 PM
QUIKSILVERZ's Avatar
QUIKSILVERZ
wow some big numbers for stock cubes. plus some great times
Old May 7, 2009 | 04:39 PM
  #33
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Well I am not suppose to be here I guess I opened the wrong door.
Power-520/500
Compression-stock
Power adder-A&A Vortec SI
Boost-8lb
Fuel- pump
Timing-stock
Bottom end-stock
I will go to the back of the line!!!
Old May 8, 2009 | 01:52 AM
  #34
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Default Forged 347 D1SC
All info is in the signature and making 15/16 lbs of boost via D1SC, with ECS 8 rib pulley set-up and ECS fuel system (and tuned with methanol turned off) and believe 17 degrees of timing (may have to kick that up a tad as my torque is lower than it should be)!
710rwhp
563rwtq
Old May 8, 2009 | 09:39 AM
  #35
Slow Z06's Avatar
Slow Z06
Power: ??????
Compression: Stock
Power Adder: Twin Garrett 70mm
Boost: 10.8#
Fuel: 60# Motrons, KB BAP
Timing: 13*
Bottom end: Stock
Old May 8, 2009 | 09:44 AM
  #36
clemsondave's Avatar
clemsondave
Wow, I'm feeling kinda wimpy!
Power: 595/495 (ran 10.12 @ 136)
Compression: 10.5:1
Power Adder: P1SC 3.9"
Boost: 9psi
Fuel: 93 Octane + Meth (100 + meth on track)
Timing: 17*
Stock longblock LS6
Those numbers might change in a week or so.
Old May 8, 2009 | 09:49 AM
  #37
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by 95BlueBomber
641rwhp 536rwtq
ummm, yeah you didnt follow the OP's instructions.
To Post up stock cube numbers!
Old May 8, 2009 | 10:54 AM
  #38
03blackZ06's Avatar
03blackZ06
[QUOTE=EVLZ06;1569980818]Lets see all those weak sauce 346/347ci numbers! I have seen several posts with peoples numbers and or builds, but want to see the different combos that are making some serious power while doing it on stock displacement!
Include:03 z06
Power: 650 rwhp and 585 rwtq
Compression: 10.5-1 Stock ls6
Power Adder: d1sc procharger
Boost:9lbs
Fuel:60lb injectors and msd boost a pump also meth
Timing: not sure
Bottom end: Stock ls6 plus cam and springs [QUOTE]
here ya go for me
Old May 8, 2009 | 11:33 AM
  #39
EVLZ06's Avatar
EVLZ06
[QUOTE=03blackZ06;1570007372][QUOTE=EVLZ06;1569980818]Lets see all those weak sauce 346/347ci numbers! I have seen several posts with peoples numbers and or builds, but want to see the different combos that are making some serious power while doing it on stock displacement!
Include:03 z06
Boost:9lbs
Timing: not sure
Stout numbers man! Think I should have went with a little more compression on my build
Old May 8, 2009 | 11:34 AM
  #40
EVLZ06's Avatar
EVLZ06
Compression: 10.5:1
Boost: 9psi
Timing: 17*
Stock longblock LS6
Hmmm did you find what you were looking for?
