Flashing MIL/P0300 Code
Old Jun 13, 2009 | 06:36 PM
alzo6's Avatar
alzo6
Default Flashing MIL/P0300 Code
after i had my ARH headers and cat pipe installed, i did a 3rd gear WOT run and the check engine light flashed a few times and went out. I checked for codes and the 0300 misfire code came up any ideas of what should be done ? any advice is appreciated thanks 01 ZO6 ECS Novi setup
Old Jun 13, 2009 | 07:54 PM
ONE BMF's Avatar
ONE BMF
Are you running NGK TR6 plugs ?? clear your codes and see if it comes back -- check your plug wires to make sure they are on tight
Old Jun 13, 2009 | 09:38 PM
alzo6's Avatar
alzo6
i believe they are the correct plugs, and wires are tight, car ran hard, seems like it was a little too rich during the wot blast, then the mil starting blinking
Old Jun 15, 2009 | 09:16 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I would have it checked out, it could be a few things, but I wouldn't lay into it until you find out what it is.
Like ONE BMF said, plugs-wires-coil pack-valve spring, are the most common causes assuming your tune was on prior to the header install.
To Flashing MIL/P0300 Code
