Bad IAT sensor?
Old Jul 9, 2009 | 10:21 PM
whitelite's Avatar
whitelite
Default Bad IAT sensor?
Do you tuners see many of these??????
My IAT's have hit 199deg at the end of 1/4 mile and my tuner says "the car would have to be on fire to get IAT's that high"
Please chime in
Old Jul 9, 2009 | 10:25 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Z06 wanted was at 250 degrees at the end of the 1/4 and I was at 175 without Methanol at 18psi boost. Your car wouldn't have caught on fire. If your maggie is intercooled, you might want to check to make sure the pump is working and flowing in the proper direction, the reservoir is full and the heat exchanger is free of debris. If it's not intercooled, then the IAT's may be in line.
Old Jul 10, 2009 | 08:13 AM
AlwaysInBoost's Avatar
AlwaysInBoost
WOW thats hot.
after a 20 minute session on the road course hitting 145+ lap after lap the highest IAT I recorded was 165 for a few seconds. Average temp according to EFILive was 122.
Old Jul 10, 2009 | 08:34 AM
whitelite's Avatar
whitelite
Livernois Motorsports tells me that IAT sensors go bad a lot. I'm replacing mine today but other than feel from the go pedal I have no way of knowing if it was bad........
Old Jul 10, 2009 | 09:12 AM
BLOWNBLUEZ06
well make sure to follow up and let us know if that fixed it.
Old Jul 10, 2009 | 01:01 PM
stainless40cal's Avatar
stainless40cal
Correct. Once you heat something up over and over and over again and the it cools over and over and over again. It becomes brittle and eventually will break.
Old Jul 10, 2009 | 10:03 PM
whitelite's Avatar
whitelite
Well, I pulled the sensor out today and it was definately damaged.
It actually looked kinda MELTED. I know that the sensor should not get hot enough to melt but the protective cage around the tip is GONE
I test drove it with the new sensor but really couln't tell any SOP difference. Gonna have to call Dr Phil one of these days and get the IAT's looked at.
To Bad IAT sensor?
