nitro methane
Old Jul 13, 2009 | 02:57 PM
Toby Van Horn's Avatar
Toby Van Horn
Default nitro methane
At work today I was talking to a tech that used to work for whipple. He says there were a lot of guys running nitro methane instead of meth as it does not change the A/F ratio?
I know there are many people here with a lot of knowledge, is there a benifit to nitro methane? It sounds like a lot of the issues from meth come from the changing of A/F ratio and if the pump fails the car may run lean?
Old Jul 14, 2009 | 08:11 AM
chuntington101's Avatar
chuntington101
i heard it would evapourate faster than meth and thus give greater cooling than meth (similar specific/laten heat capacities i think).
Chris.
Old Jul 14, 2009 | 11:05 AM
Warp Factor's Avatar
Warp Factor
Nitromethane would change AF ratios, because it's a fuel which still requires oxygen to burn completely. It may change AF ratios a good deal less than an equal volume of meth though.
Another downside: Kinda pricey.
One other potential problem: It has very different burn characteristics than meth or gasoline, and behaves like it has a very low octane. Meth will increase octane.
Maybe it would work though. We ran varying percentages (mixed with alcohol) in model aircraft engines without needing to make any other changes.
To nitro methane
