Just installed my Maggi M112, 500 rwhp 407 torque, however I do have 11 to 1 243 z/06 port and polished LPE heads 2.02 intake, kooks headers 228/588/114 LPE cam with 40,000 miles. I had the car dyno'd by Ed Wright. I realize the conservative tune with the high cr, but I would expect my torque numbers to be higher.
I spoke to Maganson and LPE with the stock 6 lbs pulley and 11 to 1 comp ratio headers, and high flow heads they said the numbers were right. Do I have belt slip, any advice would be appreciated.
v/r
THE YAV
Low torque for a maggie for sure. For a reference: I did an install on a stock Z06 with just headers and at 6-7psi it made 504rwhp and 480rwtq...Which is probably close to what you should have..I was at 490rwhp and 460rwtq on my stock LS1 with just a small 224 cam and headers at 7-8psi..Any kind of knock or false knock will pull timing and hurt your torque numbers..
My first thoughts would be HEAT SOAK and hot IAT temps along with some timing being pulled due to, either, Heat Soak or Knock Sensor pulling timing!
Usually a MAGGIE has close to the same amount of TQ as RWHP - did they watch the Voltage gauge to see if it was dropping!
If so then you will be seeing belt slip - this means when it is slipping the Alternator is not getting full spin in the uppper RPM's (I do think this is the same for the MAGGIE as is for other SuperChargers)
I will be able to scan the dyno sheet on Monday, I can't say heat soak the car temp never gets over 200 degrees on a 95 degree hot Kansas day. Usually runs between 186 - 196 in stop and go traffic.
What do you do for belt slip? In addition could I have a fouled plug?
As stated eareiler the dyno sheet may hold the clues.
v/r
THEYAV
Thanks,Matt
Is this always true? If so it would be a great way to check for belt slip. However it seems to me like the belt could easily slip on the supercharger pulley and not slip at the alternator. The SC has a lot more resistance than the alternator. I usually just watch the boost gauge and check for belt dust to indicate slippage.
The heat soak problem with a maggie they are referring to is the intercooler water. It gets hot real fast sitting on a dyno and the efficiency of the intercooler drops real fast....
Thanks for all the info,
Today I hooked up a scanner....Zero spark knock, intake temps were 135-140 range, 95 degree day the car never went over 195 back down to 185. No misfires all cylinders working.
I did find a lose vacuum line near the (silver) spark controller. I had only 68 miles since the retune and the car seems to be getting stronger.
My cam specs again are .228 duration / .588 lift / 114 CL. I think that it’s a very conservative tune with the mods and cr I have about 4 LBS of boost.
I guess I will have to get some heads with 10.5 to 1 cr a retune and
smaller pulley.
Gentleman,
I can not post my dyno sheet on the forum, if I could send someone the dyno sheet by e-mail to look at to give me direction. Thanks.
v/r
THEYAV
Gentleman,
v/r
THEYAV
Email me the sheet (davefra-AT-hotmail.com) and I'll host it on my server, then I'll post it here. I'm real interested in getting a Maggie, so I'm curious to see how this all plays out.
v/r
THE YAV
Something is not right. I hope people can help you out. Am I the only one that thinks the HP is on the low isde? I would have thought you would've gotten more considering you have heads and cam to go with it.
