Wtf?
Old Jul 26, 2009 | 01:40 AM
mulalleybs's Avatar
mulalleybs
Default Wtf?
So I've broken 5 serpentine belts thus far. 3 of which happened in the last 2 weeks. I don't get why they keep breaking.. -_- btw I have the ecs s/c kit with 600rwhp.
Old Jul 26, 2009 | 05:30 AM
willig72's Avatar
willig72
Well call ECS I am sure they can and will be very happy to help you.
Old Jul 26, 2009 | 08:29 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Soo sounds like an ALIGNMENT issue
Look to see if you see any belt dust/powder on any componants, this will at least point you in the right direction.
Let us know what you find!
Thanks,Matt
Old Jul 26, 2009 | 08:55 AM
EPP's Avatar
0EPP
Former Vendor
Thanks,Matt
I agree, an alignment problem is the number 1 belt related problem. Bob
Old Jul 26, 2009 | 01:21 PM
mulalleybs's Avatar
mulalleybs
So I checked out my engin e bay and noticed there is a little bit of black dust on the side of my s/c near the pulley and a little right underneath the pulley on one of the spacers.
Old Jul 26, 2009 | 01:25 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
You need to get one of those alingment tools and narrow it down to the actual area needing worked on
Old Jul 26, 2009 | 01:28 PM
mulalleybs's Avatar
mulalleybs
Hmm how could it be unaligned though when all the brackets are factory and ECS brackets? If it were unaligned how would I go about fixing it? Where can I get an alignment tool and how do I use it? Lol
My friend thinks I need to just upgrade to an 8 rib, but I don't think there should be this many belt issues with only 600hp, I haven't read about anyone else having this much trouble with their 6 rib.
Thanks,
Brett
Old Jul 26, 2009 | 01:36 PM
user_name's Avatar
user_name
The dust is from belt slip. A little bit is normal imo as long as your boost curve keeps going up(centri) or flat and not dropping(maggie).
Seems to me like the belt would be frayed and worn if the alignment was bad. Unfortunately I speak from experience here.
Old Jul 26, 2009 | 01:49 PM
leo12's Avatar
leo12
forget the expensive pulley lasers...all you need is a cheap ten dollar carpenters laser set it on one side of the car on the fender or hold it in hand you will see what pulley is off..simple...i did it two years ago have not broken any belts sence 15 ponds of boost 750 RWHP and it does see full boost a lot
tail_lights's Avatar
tail_lights
Also, how tight are you going on with these belts?
Old Jul 26, 2009 | 01:53 PM
mulalleybs's Avatar
mulalleybs
Well since this if the 5th belt broken now we've gone from cranked down almost all the way to half way and they keep breaking.
Old Jul 26, 2009 | 02:07 PM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
the factory tensioner could be shot, I ran into those issues last fall even with my 8 rib...
Old Jul 26, 2009 | 02:18 PM
mulalleybs's Avatar
mulalleybs
talking about the auto tensioner? I have the ecs auto tensioner
Old Jul 26, 2009 | 02:53 PM
4DRUSH's Avatar
4DRUSH
Your better off calling ECS and have them diagnose your problem. Don't get all worked up listening to these guys trying to help. If your throwing belts it's an installation or adjustment problem, chill out and wait till tomorrow.
Old Jul 27, 2009 | 12:53 AM
mulalleybs's Avatar
mulalleybs
The first of the 5 broken belts lol
The belt that broke last night
Old Jul 27, 2009 | 08:53 AM
chriswtx's Avatar
chriswtx
Been there...ALIGNMENT issue, not every car is exactly the same..So its possible to have and alignment problem..The Gates laser tool is the best way to check it...If you look around you might be able to find one local that you can borrow...
Old Jul 27, 2009 | 01:16 PM
undertaker's Avatar
undertaker
auto tensioner?
I'm talking about the spring loaded one off to teh passenger side of the crank pulley that gets relocated with the blower, not the one on the head unit bracket itself. Those can go soft, it should be the pain in the *** part of changing the belt.
To Wtf?
Old Jul 27, 2009 | 01:43 PM
Max@Cartek's Avatar
Max@Cartek
Yup
Old Jul 27, 2009 | 02:07 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
auto tensioner?
We have never had a spring loaded tensioner go soft? Your tensioner broke and if you remember you guys had installed several of the idlers and bracketry incorrectly, which we found when we repaired it for you N/C. Which was why it broke...
OP, feel free to give us a call. Something is installed incorrectly, shouldn't be very hard to find.
Old Jul 27, 2009 | 02:13 PM
ForceFedC5's Avatar
ForceFedC5
I've noticed that if a belt breaks, and you do nothing to fix the problem but put another belt on.. my guess is that one will break also.
Just call them and get it solved!
