question about meth install
Old Jul 26, 2009 | 09:04 PM
69dodgecharger's Avatar
69dodgecharger
Default question about meth install
Hi, I have removed a alkycontroll kit from a 02 zo6 and am installing it on a 05 C6. I have all of it done except for one wire. The green trigger wire that goes to the map sensor.
On the 02Z it was ran to a wire on the ECM, not a map sensor like the kit supplies. Is this doable on the C6? Anyone know which wire it would hook up to on the c6 ECM?
Old Jul 26, 2009 | 10:59 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Sounds like the installer might have used the factory MAP wire. The C6 has a MAP sensor, so if the input impedance is high enough on the Alky kit to not interfere with the MAP signal going to the PCM, I don't see any reason you can't wire it up the same way.
Old Jul 27, 2009 | 12:59 AM
69dodgecharger
Ya thats exactly what the installer did. Now anyone know where the wire is on the C6 ECU?
Old Jul 27, 2009 | 07:09 AM
BLOWNBLUEZ06
Try grabbing it in the harness closer to the MAP. You have a 5v supply, ground and your output, which I believe is in the middle. Use a DMM to verify. It will be ~.5v at idle and 4.7V+ at WOT. Once you verify its color, you can chase it back to the PCM if you care to.
To question about meth install
