No Boost:
Old Aug 13, 2009 | 08:49 PM
Mike Plummer's Avatar
Mike Plummer
2018 C5 of Year Finalist
Default No Boost:
About a month ago I noticed my maggie was not producing boost at least according to the gage. I took the following corrective action, replaced my belts to include the one on the back of the maggie...its been on there awhile. I figured while I was replacing belts I would install the new ECS tensioner for the maggie, nice piece, and a 3.2 pulley for kicks. Got her running again today and no Boost...needle measures vacuum but never goes to more then 1Lb on the Boost side. Is there an easy way to verify if my gage is doing its job or should I be looking elsewhere?
Thanks Mike
Old Aug 13, 2009 | 09:05 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Thanks Mike
try another gauge. a cheapo one from advance auto just for testing one is fine.
what kind of gauge are you using anyways?
Old Aug 13, 2009 | 09:26 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
There is a valve on the blower with an actuator on the driver side with a vacuum hose running to it. There are other hoses going to the inlet very close to it at the front of the blower. Make sure the hoses are clear of the actuator mechanism. You won't make any boost if one of those hoses holds the bypass valve open. When you rev the motor with the hood up, you'll see that actuator moving. Make sure it has free operation.
Old Aug 14, 2009 | 12:45 AM
Mike Plummer
Default No Boost:
I will check both in the AM...current boost gage is an auto meter installed with the unit at LPE..Thanks for the help...MJP
Old Aug 14, 2009 | 01:10 AM
Scubanme's Avatar
Scubanme
My car makes a heck of alot of noise when the Blow-off valve goes off, so there is no doubt whatsoever if it is boosting or not, I guess supercharged cars don do this?
Old Aug 14, 2009 | 07:29 AM
BLOWNBLUEZ06
Your supercharger must not be a Magnuson then because the bypass valve is integrated in the blower housing.
Old Aug 14, 2009 | 12:43 PM
heavymetals's Avatar
heavymetals
There is a guy on the V forum that had no boost and he found that the three coupling pins (plastic) inside were sheared off.
These couple the rear pulley/to the lobes.
http://www.cadillacforums.com/forums...i-have-no.html
Old Aug 14, 2009 | 05:51 PM
clif's Avatar
clif
St. Jude Donor '09-'10
My car lost boost a month ago. I replaced the pulley to a smaller one thinking it will now make boost! ( I have a ProCharger). Well, I could only achieve 4 PSI no matter what I did. I took it to a shop to check out, and they did not find anything. Finally, I put my car up on ramps, and shook every hose. I found a hose loose inside the right front fender cover where one of my two intercoolers was mounted. I reattached the hose, and found out I am not pushing 10.8 PSI boost at 5K! Wow! I need to go to a larger pulley before I blow up my stock bottom end!
All this is just to say, see if there is any hose that may have come loose. Did it used to boost and then stopped? My hose had backed off just enough to let the air out, but a visual inspection could not detect it.
Old Aug 14, 2009 | 09:42 PM
Mike Plummer
Default No Boost SOLVED!
Problem solved BlownBlueZ06 had it correct a vacuum hose from the breake booster running near the right front of the maggie was causing the actuator to hang in the open position...thank goodness it was simple I have a huge smile on my face with more boost then ever with the new pully
Thanks guys...Mike
Old Aug 14, 2009 | 10:39 PM
BLOWNBLUEZ06
glad you found it! Simple fix to get some boost back in your life.
Old Aug 16, 2009 | 03:16 AM
heavymetals
Maggies are fun!
To No Boost:
