something broke
Old Sep 6, 2009 | 04:41 PM
c5mtl's Avatar
c5mtl
Default something broke
did a compression test and #5 is at 30 the rest are about 180....all kinds i mean tons of smoke out from breather....I guess it didnt like 13.5 psi ....Any deal going on on shorts....what are the pros and cons to iron or alum block ....347 or 400+....i dont really want to get into a fuel system yet and want to stay with my s trim for this year....
Old Sep 6, 2009 | 04:46 PM
95vettski's Avatar
95vettski
Sorry to hear about your motor Get in touch with Rob@Champion Motors for a short block, your only 5 hrs away! He has plenty of blocks in stock and the turnaround time will be quick.
Old Sep 6, 2009 | 05:02 PM
c5mtl's Avatar
c5mtl
one of my options for sure...its just with the current us/can exchange rate the us vendors are looking good
Old Sep 6, 2009 | 06:15 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Yeah! bring us money!!! We're broke!
Sorry about your troubles. When my motor let go, I considered it a blessing. Forged is more fun!!
Old Sep 6, 2009 | 10:32 PM
TRIZ's Avatar
TRIZ
Is the block OK? Can you reuse it?
Old Sep 7, 2009 | 01:14 AM
c5mtl's Avatar
c5mtl
not sure what kind of damage...car seems to run...ok....even pull pretty decent....dont really want to start it.....maybe going to rent one of those camera scopes and check it out and see if the piston is broken....what kind of damage would cause a 30 reading on a compression test...broken ring or broken piston
Old Sep 7, 2009 | 06:38 PM
TRIZ's Avatar
TRIZ
Don't start it.
Pull the head and check it out.
Camera scope's not a bad idea though.
Mine blew the #7 (tuner was doing a dyno pull) and broke off the top of the piston and exposed the ring (about 3 yrs ago.) She was puffin' out the breather cap.
Did you see any white smoke from the tail pipe?
Old Sep 7, 2009 | 06:52 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
multiple reasons.
  • hole in a piston
  • melted/broken ringland
  • broken ring
  • cracked liner
  • broken/bent valve
  • blown head gasket
Old Sep 7, 2009 | 07:18 PM
Slow Z06's Avatar
Slow Z06
I feel your pain man. I had smoke from the tail and breather. Did a leak down and had over 35% on 1 & 3. Havnt got mine out yet but that was enough for me to pull it apart. Hope you get it fixed up soon.
Old Sep 9, 2009 | 03:57 AM
c5mtl's Avatar
c5mtl
no smoke from exhaust..no white smoke.....oil looks fine ...car even pulled ok...i knew something was up so i didnt push...pretty sure its not a valve....i used the stephescope to listen and really didnt hear anything out of the ordinary....not ready to take it apart because one way or another the car is still mobile....going to camera it...
Old Sep 9, 2009 | 08:59 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Same thing that happened to me when I was on the stock block, pistons and rings! I lost my #7 rings and this is what sounds like happened to you!
I went with the LS1 347 Forged (My stock block) niw with 14 PSI of BOOST and 701 RWHP
I love it and it is totally reliable
Thanks,Matt
Old Sep 9, 2009 | 01:12 PM
corvette01's Avatar
corvette01
heyy sorry to hear about your engine...same thing happend to me about two weeks ago..smoking heavily out of the breather oil all over engine compartment and running down engine...did compression test and #7 was the bad one so going to pull the engine hopefully friday and figure out what it needs... I was just wondering if anyone here has pulled the engine out before and maybe can provide some help on making it easier.. looked on line got a few printouts but anything is helpful guys... thank you
Old Sep 9, 2009 | 10:33 PM
c5mtl's Avatar
c5mtl
was some options...new short from lpe 347 with all the nice stuff reuse my heads cam and other stuff...or get into a 402 thats for sale on the other forum....will my s trim be okay for a 402....also with such a big stall that im running ...wont the 402totally blow the tires off???I dont want to get into a fuel system this year..next year plans are fuel system and a t trim or ysi....so 402 or 347....below is the link to the used motor
http://www.ls1tech.com/forums/lsx-pa...s-inj-etc.html
Old Sep 9, 2009 | 10:38 PM
MotleyDrew's Avatar
MotleyDrew
I personally wouldn't buy a used motor when you can get a nice 347 fresh instead. The S-Trim will mate up nicely and you will be good to go.
Old Sep 10, 2009 | 01:19 AM
c5mtl's Avatar
c5mtl
thx dude...thats what i was also thinking....
Old Sep 10, 2009 | 12:47 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Plus the the 408 had very high compression 11 to 1.
Old Sep 15, 2009 | 01:12 AM
c5mtl's Avatar
c5mtl
looks like im going with either lpe or a small engine shop with a great history....going to stick with a 347...going to step up to a T trim and a 8 rib setup with a 10 % innovators west overdrive crank pulley and run a 3.125 pulley...any ideas if im going to run out of fuel ...currently i have the pump supplied by a&a and a dual nozzle meth kit and 60 pound injectors...also insatlling an lg big 3 system...all i need is some fuel and im going to max out that blower
Old Sep 15, 2009 | 05:18 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would do a stock size balancer and go with a Cartek Flip drive. You'll save yourself a lot of money and aggravasion as you only have to deal with the crank and blower pulley.
http://forums.corvetteforum.com/c5-f...rsion-2-a.html
Old Sep 19, 2009 | 07:01 PM
c5mtl's Avatar
c5mtl
what do u guys think...when will i run out of fuel?and do you think a 3.125 with the over drive crank will spin the blower fast enough ??
To something broke
