Which Balancer do you run?
Old Sep 17, 2009 | 04:26 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Default Which Balancer do you run?
Which Harmonic Balancer do you belt driven blower guys run? Thanks
Old Sep 17, 2009 | 05:31 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I run with the STOCK factory balancer and a FLIP-Ditty-Do-Dah-DRIVE (FLIP-DRIVE by Cartek-absoloutly awesome )
I am @ 14.4 PSI on a P1SC-1 with 701 RWHP and 582 RWTQ!
Thanks,Matt
Old Sep 17, 2009 | 05:46 PM
robert miller's Avatar
robert miller
Thanks,Matt
Matt, that is good on 14psi and on a P1 UNIT.
Old Sep 17, 2009 | 05:50 PM
madmatt9471
I know and it's like effortless too - I am gonna slap on my TI Mufflers when I get home from work tonight, and when it cools down some I am gonna get it re-dyno'd because it is still a little too "FAT" in the AFR dept.
Get that cleaned up and it should have couple more ponies - but it will just be a number, which is okay with me, but I will take it to the track and really see what it does
Thanks,Matt
Old Sep 17, 2009 | 09:12 PM
ONE BMF's Avatar
ONE BMF
ATI SuperDamper
Old Sep 17, 2009 | 09:17 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Innovators West 8" (10% overdrive). It allows about 2 more psi without having to swap pulleys.
Old Sep 17, 2009 | 09:56 PM
TRIZ's Avatar
TRIZ
I have an Innovator's West 8" 8-rib to help drive a weak little YSi.
Got it from Jeff.
Old Sep 17, 2009 | 09:59 PM
black98c5's Avatar
black98c5
Innovators West 8".
Old Sep 17, 2009 | 10:47 PM
EVLZ06's Avatar
EVLZ06
IW 8" to help spin my lil F1
Old Sep 17, 2009 | 11:32 PM
denscor's Avatar
denscor
same here!
Old Sep 18, 2009 | 09:49 AM
HP_Addict's Avatar
HP_Addict
ATI here
Old Sep 18, 2009 | 12:49 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
We use the Innovator's West 8 incher...
Old Sep 18, 2009 | 12:59 PM
MotleyDrew's Avatar
MotleyDrew
Old Sep 18, 2009 | 01:02 PM
tail_lights's Avatar
tail_lights
Stock for now. Going to go 8 rib as soon as the wallet lets me
Old Sep 18, 2009 | 03:56 PM
corvettebob1's Avatar
corvettebob1
Originally Posted by ONE BMF
ATI SuperDamper
Old Sep 19, 2009 | 07:23 AM
clif's Avatar
clif
St. Jude Donor '09-'10
Innovator's West 10% for me too!
Old Sep 19, 2009 | 11:25 AM
HotRod68Camaro's Avatar
HotRod68Camaro
I noticed the ZR1 can run a 8.5", has anybody considered running a custom 8.5"? Or would that just max out the centris early?
To Which Balancer do you run?
Old Sep 19, 2009 | 11:49 AM
Brandon619's Avatar
Brandon619
The ZR1 balancer is a 10 rib and would require moving the power steering rack forward if it did fit the crank snot. There has been poeple on this forum that have made custom 10 rib set ups.
Innovators here
Old Sep 19, 2009 | 12:42 PM
HotRod68Camaro
Innovators here
Yea i understand that, maybe i need to clarify what i mean. Im not talking about taking a ZR1 pulley and using it on the C5. Im talking about just getting someone to make a custom 8 rib just in a larger 8.5" diameter, im wondering the pros/cons of it.
Old Sep 19, 2009 | 12:48 PM
RED99's Avatar
RED99
I dont think you can run anything bigger than a 8" unless you went with a smaller water pump pulley, and Im not sure it that is possible, or a good idea. If I remember correctly, my 8" pulley is really close to the water pump pulley.
