Why Meth?
Old Sep 24, 2009 | 10:32 AM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Originally Posted by intoc6s
Would Methanol add anything(hp-wise) to a High compression/427 engine? I know i would need a tune for it, but would there be any benefit? It runs strong on 93-octane with this tune.
How about if i ran a 125-200 shot of Nitrous + Methanol?(on my 427) Thanks In Advance!
I would not bother running Methanol on a NA engine.
There are some octane benefits with it, but I think the controls would be much harder to work out right.
Same thing with Nitrous, If you are going to the expense of running a second fuel system for it, would use a fuel cell with C16 in it. Build a recirculating system like a mini fuel system for it. You can talk to Julio about this, I have and he can do it, but IMO there are better ways to skin this particular cat.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Sep 24, 2009 | 11:28 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Originally Posted by Z06supercharged
Did you just drill and tap a hole in the intake? Im sure you just didn't use a grommet otherwise it would blow out with high boost wouldn't it?
Motley Drew used something like acetone to plastic weld the IAT sensor in his intake. I did in fact use a grommet and made sure it was it tight fit. 18psi boost and never an issue. It is a tight fit. I would bet the intake would blow apart before my IAT sensor comes out.
Old Sep 24, 2009 | 12:00 PM
Z06supercharged's Avatar
Z06supercharged
Interssting..I like it. So im assuming you put it on the top right behind the TB in that roundish open area? I need to do that and that would be the perfect place for it. So you just used a stock grommet for the IAT sensor then correct. Do you remember what size the hole was you popped in there?
Old Sep 24, 2009 | 02:02 PM
BLOWNBLUEZ06
I don't remember. I used a Unibit and ran it down until I got a tight fit.
Stock Grommet. Yep. If you drill the hole a little small, you'll get a tighter fit on the sensor. I almost had to jump up and down on mine to get the sensor to push through the grommet. That's why I say it won't be coming out any time soon.
Here's Drew's
Here's mine on a LS2 intake. Look off to the left next to the MAP sensor.
