My set up is the ECS SC600
extra mods are textrilla clutch
Julio meth kit from ECS
Synapse BOV
MSD coils
MSD Boost a pump
i don't know about AF ratios so i was looking for advice is my car looks like is lean. looking at the AF graph or do u need more info the car feels good i just want to see if what i got is good
if anything thing, the 514hp run has a few spots that are very rich, could still use a little tweaking to straighten out the AFRs a little. But rich is safe on a stock bottom end..
Doesn't look lean to me. Looks fine. Maybe a little belt slip above 5700rpm though..
When using the dyno wideband, there is a time delay for the exhaust to actually hit the sensor. You have to keep that in mind when tuning on the dyno or reading the sheet. Looks good other than the probably belt slip.
Well i really appreciate all the coments. Now second question since i got the 343 code i am going to be installing a ECS cam with com cams 921 springs harden push rods and doubel roller timing chain. How i go about starting the car afther the install is it safe to turn it on and drive to the tuner or not i never have install a cam but i got all the tools inc the cam deggre tol from com cam. Help on this one
I don't know what your hp goals are but I would save the cam swap cost fix the cam bolts and enjoy the car and its new found power and next mod would be forged. Dollar for dollar its a better deal because most likely its inevitable you will have to do it anyway at some point even more so if you do the cam swap you will be at the motors peak of being reliable.
So is not worth the risk pushing my bottom whit the cam up grade. Ok but i am adding the springs the doubel timing chain and harden push rod for extra ins will i see extra hp will i need a re tune
Unless the belt was left very loose, you most likely had a degree or two of knock, over a slipping belt. Belt slip usually drops harder once it starts, knock retard just drops the graph in a step, which is more of what yours looks like to me.
If your going to do a cam at the same time as the cam bolts, I would strongly recommend alky injection at the same time. Otherwise I would just wait until you do a fully forged engine.
(btw this is Doug @ ECS on Mikes lap top)
This set up was installed at ur shop and i do have the meth kit the reason why it was retune at this shop was because it keep trowing me codes on bank 1&2 too rich so i had the vech retune at C.A.M i call chris and tolld him about my problem but unfortunally the shop u guys work with her in NC was too far for me so i dicide to pay out of pocket and re tune. I love the work u guys did but i dont like what i found in my dyno sheet bc it was very diferent from what u guys send me. Pleas no body pm me or ask bc i dont want to start nothing i like ecs and all of their products and i can call them any time and chris will talk to me I guess it was the weather
Let me give you a honest answer. I have a 04Z with a novi and the same goodies you have on a stock long block which all was installed by ECS and at 8psi 581rwhp 488rwtq. I don't drive this car much so my stock block is fine. I called Chris ECS and told him I want to drop my car off for a cam upgrade and he said not to waste my money and wait for a forged motor because how much more will we get out of a cast piston before kaboom.
I really apreciate ur honest opinioni will trully callit quits before kaboon so the finall question i am going to tight down the cam bolts and ad the com springs 921 with harden push rods do i need re tune and will i see hp increase with tune or with out the tune
I couldn't tell you so what I would do is give a call to ECS Monday morning and ask them you won't get a more accurate answer anywere else
