Maggies with Meth Warning!
Old Nov 5, 2009 | 11:04 AM
Vega$Vette's Avatar
Vega$Vette
Default Maggies with Meth Warning!
I have posted up in the past the hazards of using Meth/Alky with Maggies.
Yesterday at SEMA I had a long and detailed discussion with Magnuson about this very issue.
I was told face to face that without a doubt spraying meth/alky/water will ruin the Teflon coated rotors in a Maggie.
Paraphrasing the best I can.
Maggie rotors are Teflon Coated to close tolerances and during the first few minutes of use wear-in to create optimum seal through a process they refer to as fingerprinting. When sprayed it changes the FP and will caused chipping that leads to the Teflon coming off. They have seen rotors that look like they were bead blasted and polished due to injecting fluids.
Old Nov 5, 2009 | 11:10 AM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
That's why you buy a PD blower with no Teflon.
Old Nov 5, 2009 | 11:30 AM
Boob's Avatar
Boob
That sucks! I'd called them about this very issue and heard pretty much the exact opposite. They said that if the teflon was cheaply put on that it'd flake etc. This was a while back though. Also called Snow about it and they said spraying meth was ok as long as it wasn't into a centri/turbo because of the speeds the blades get to.
Old Nov 5, 2009 | 11:37 AM
SmoothFRC's Avatar
SmoothFRC
... can you spray after the rotors? or would that be just plain stupid? i know you would loose the cooling effects onto the rotors - but isnt the IC after the rotors anyway? Maybe just spray on top of the IC?
Old Nov 5, 2009 | 01:03 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I will have to look for it now, but I have IN WRITING, from Magnuson, the OK to use methanol injection with their chargers.
Between that, and that now we have had customers making big power (for a Maggie) with meth injection for years now, and many-many miles, I would not hesitate for a second to use meth injection.
I'm not sure who gave you that info, but it does not coincide with our findings, or what their engineers clearly stated to us.
hope that helps.
Old Nov 5, 2009 | 01:14 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Man do I love my Centri
This is good info I just hope it's not oo late for a lot of Maggie owners
Thanks,Matt
Old Nov 5, 2009 | 02:52 PM
Blue Lightening's Avatar
Blue Lightening
I don’t buy it. This has been brought up before and to date has been nothing more than unsubstantiated hearsay. If it were true I think someone would have posted details along with pictures by now.
Old Nov 5, 2009 | 02:55 PM
Boob's Avatar
Boob
I run a maggie with meth in my CTS-V. No issues to date, a little over 10k miles on it so far. (not including previous owner)
I do plan to post pics of the rotors if I ever take it off to get reworked/upgraded for just this topic.
Old Nov 5, 2009 | 03:23 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
This isnt new. This has been a known fact for years now. The coating on the rotors will start to come off after long use of methanol.
That being said, it doesnt take away from the fact that it still works well. The maggie dosent internally compress the air, so it's not dependent on the extremely tight tolerances like the twin screws. What this means, is you can still have bead blasted rotors, and still work just fine. Its not until it gets really really bad, that it has an issue.
Its really one of those "pick your poison" kinda things.
BTW, anyone see those Edelbrock TVS units at SEMA?? WOW those were nice. They said they tried to work with maggie, but were told to pound sand. So they went to Eaton (Maggies parent company). Regardless, they look really nice for a low/moderate boost application.
Old Nov 5, 2009 | 03:34 PM
Vega$Vette's Avatar
Vega$Vette
Talked to the Edlebrock guys for a while. They have some very nice products. We tried to impress on them the C5 market for the blower. They guy we talked to was all for it but said they didn't want to have to go with a hood change and really wanted to try to figure a way to fit it with the stock hood but it just wouldn't work.
I would expect they may develop a hood and/or sell it as a tuner package for the LS1
btw it seemed like every Camaro there had a Maggie on it!
Old Nov 5, 2009 | 05:49 PM
HRTBRCR's Avatar
HRTBRCR
hope that helps.
no offence, but ECS has my vote, sorry if I sound biased
they went 10's with a maggie, and nobody else is even close....
Old Nov 5, 2009 | 08:29 PM
Vega$Vette's Avatar
Vega$Vette
I'm just telling you guys what I was told face to face by Magnuson at SEMA yesterday.
You can choose to believe it or not.
I have the utmost respect for ECS but I still would tend to believe the manufacturer.
btw. There have been quite a few Maggie C5s in the 10s
Old Nov 5, 2009 | 10:23 PM
FunCool's Avatar
FunCool
hope that helps.
Old Nov 5, 2009 | 10:26 PM
FunCool's Avatar
FunCool
I've had meth spraying into my Maggie for 6 years now and it can still make 20lbs of boost!!!
Old Nov 5, 2009 | 10:58 PM
robert miller's Avatar
robert miller
If you dont believe funcool just dont spray your car. This with I think a 250 shot of NOS also for a long time.
Old Nov 6, 2009 | 01:42 AM
rudolph schenker's Avatar
rudolph schenker
Old Nov 6, 2009 | 11:04 AM
Toby Van Horn's Avatar
Toby Van Horn
so doug, if you don't mind me asking what kind of numbers / build are you putting down with this build?
To Maggies with Meth Warning!
Old Nov 6, 2009 | 11:22 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
Saw it, talked to them about it, a Grand Sport with that set up is in my future!
Old Nov 6, 2009 | 11:58 AM
tlaselva's Avatar
tlaselva
Funcool has gone through barrels of alky with his Maggie.
If it was detrimental to the blades, he would have been the first to see it a long, long time ago.
Believe real world results, or someone yapping. You choose for yourself.
Old Nov 6, 2009 | 02:35 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
But again, just because someone does it, doesnt make it right.
There are hundreds of documented cased with pictures on the net. We have seen dozens of rotors like that.
If the rotors are sprayed with heavy methanol, they WILL pit. Just like aluminum will pit with Alky. BUT, the maggies aren't dependent on internal compression, so they will continue to work just fine. That being said, there is no doubt that FUNCOOL isnt running alky, and doing it successfully. That is because although the Alky can hurt the rotors over a long period of time, the rotors will still work just fine until they have reached that critical point. His just arent at that point. They may never be.It may take longer than the ownership of the blower.
