which supercharger?
a). novi 2000 kit from ecs along with thier stage 2 fuel system
b) vortech t trim with fuel system from a&a
c) kenne bell. having problem getting ahold of anyone there though.
They also shut their phones off between 12-1PST. Other than that, you can call 909-941-6646.
As for ANY question regarding the kit on these cars, you can ask me pretty much anything, and Ill do my best to answer it the best way possible.
But in this section of the forum, it is HIGHLY bias towards the ECS or A&A kit. So before you make your decision, make sure you speak to guys who are currently running the kit in some fashion. Not ones who messed it up, and pulled it of blaming the supercharger.
We jus finished a 408 stroker with KB 2.6, and it is a monster.
On 10.5psi, we had to abort the run at 4750 rpms, because he dropped to 40psi of fuel pressure. He's running a stock fuel system, and it just couldnt handle it. But at 10.5 psi, he is making 652rwhp, 650.5rwtq (at 4750 rpms). The power was climbing like no tomorrow. When he finishes building his fuel system, we plan on upping the boost, and running it out to redline.
(lab tests show you should always go with your first instinct)
Feel free to give us a call if you would like to speak about your options in length.
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
But it all depends how much power you want to make. The Novi 2000 does show a bit more CFM from it. But with your engine size I say go with something bigger than the T trim and the Novi 2000 so you can make close to 1000 whp
