Balancer separation
Old Feb 1, 2010 | 12:31 AM
tjwong's Avatar
tjwong
Default Balancer separation
Any one out here with a FI application (Centrifugal blower) that had a balancer separate. By this I mean the two halves separated or as some put it spun apart. The bolt isn't loose, the serpentine outer pulley separated from the main hub that is attached to the crank. Apparently the rubber bonding material gave up on the last dyno pull, no apprarent damage other than the belt was pretty much wasted.
Old Feb 1, 2010 | 07:01 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Not me. I didn't wait that long before replacing with an O.D. balancer.
Old Feb 1, 2010 | 07:35 AM
Brandon619's Avatar
Brandon619
I've had this happen to me but I was not supercharged at the time.
Old Feb 1, 2010 | 08:57 AM
clif's Avatar
clif
St. Jude Donor '09-'10
My balancer got the 'Wobbles', so I upgraded to a Innovator's West balancer before it died completely.
Old Feb 1, 2010 | 10:30 AM
Z06supercharged's Avatar
Z06supercharged
My buddies Summit brand SFI rated to 10K balancer separated. He limped it home from the track 70 miles. Got it replaced under warranty but wasnt too happy about it. He is at 675 rwhp. The only thing holding it from flying off was the belts. Took the belts off and you could spin in.
Old Feb 1, 2010 | 01:09 PM
tail_lights's Avatar
tail_lights
It happens, don't even need to be blown. Mine was looking bad years ago so I went to an underdrive setup. Now I am back with a stocker, and back to checkin' every so often.
To Balancer separation
