Front Spring Replacement
Old Feb 28, 2010 | 09:22 PM
usmcrtr's Avatar
usmcrtr
Default Front Spring Replacement
Kicking around the idea of replacing just the front leaf spring on a FI F45 coupe with one from a Z51 suspention to compensate for the added weight. The car is not lowered, but constantly scraps the front airdam on minor bumps. Moderate braking produces the same results. Sitting on flat ground the center of the dam is maybe 2" above the ground. Change just front, both or other spring/rate?
Old Feb 28, 2010 | 09:53 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Z06 has highest spring rate, so why not get a pair of those?
