changing rockers and spring
Old Mar 1, 2010 | 02:33 AM
STEEL's Avatar
STEEL
Default changing rockers and spring
Im going to change my heads so would it be wise to change my rockers, springs etc and if so what kind? im looking for about 700 RWHP in the end with a procharger, head, cam, forged bottum end, etc.
Old Mar 1, 2010 | 03:31 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
It would absolutely be wise to change the springs. The Patriot dual Gold Extremes have done most everybody right. I would also recommend having a head shop shim the springs to match your cam specs so that you are able to take maximum advantage of the springs. Many people running the stock rockers and making your kind of power. My preference is a good, aftermarket roller rocker. Yella Terras are good. No Scorpions. I have the Comp Cams / T&D 1500's, but they're expensive and not necessary.
Old Mar 1, 2010 | 01:20 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
I like using the stock rockers with the bearings upgraded. The springs need to be matched to your camshaft.
To changing rockers and spring
