My 347 build complete (56k=death)
Old 03-21-2010, 09:24 PM
  #41
C5kid
C5kid's Avatar
Cruise-In VI Veteran
St. Jude Donor '12
nope she is running around 185-190 when i am cruising, oil temp is 210*
after a full pull the coolant will go up to 200*, but never went over that so far, oil would go up to 215* and slowly work its way down then.
Old 10-24-2010, 12:55 AM
  #42
C5kid
C5kid's Avatar
St. Jude Donor '12
back from the dead for this thread.
Finally after all summer of dealing w/ belt slip issues, it finally works.
First off a BIG thanks to easyvette for always giving good advice, BlownBlueZ06 for helping tune this thing, 3someC5 for giving me the Flip Drive he won @ Carlisle, Fartpipe for always lending a hand when I need it, plus the forum, there is a wealth of knowledge here and glad to see everyone work together. Even though we bust on each other at times
So today we had a fall dyno day, DynoJet 248. Put my car on the rollers since I have the Flip Drive installed and it has been making a consitant 13# (ATI damper, 3.0 head unit pulley, 6rib) Yea, amazing how well that FD works.
First pull I only did to 6000rpm to make sure I wasn't goin lean, it put down 578/490. Everything looked good so I said "let'er eat!!!" Took it up to 6500 and the fuel pressure started to drop so wasn't goin to take it any higher.
Finally #'s 615/524... Did back to back pulls and both times it was exactly the same. I am happy with that, for no meth, a P1 being over spun, those are some good #'s. My next upgrade HAS to be a fuel system, right now I am only running a 255 w/ a KB BAP. So it's MAXED OUT. you can see in the dyno towards the end the A/F tappered off to 12.0. It was holding 11.2-11.5, but that las 500rpm it just couldn't keep up.
Old 10-24-2010, 01:00 AM
  #43
C5kid
C5kid's Avatar
St. Jude Donor '12
oh yea, if your wondering how that intercooler setup is workign for me. I just checked my HPTuners log. The IAT temps never went over 75*. Now it was a cool day, probally only 60* outside, but I expected them to get ALOT higher from just having that little fan blowing across the intercooler.
Old 10-24-2010, 07:40 AM
  #44
Z06supercharged
Z06supercharged's Avatar
Whats are your IAT's when WOT through a few gears or your dyno pull WOT? Im assuming your 75* IAT's mentioned are just cruising around out of boost temps?
My IAT's are always 6-8* over ambient temps when cruising out of boost.
Old 10-24-2010, 09:43 AM
  #45
C5kid
C5kid's Avatar
St. Jude Donor '12
nope, got into teh boost andy went up to 75*, i will post pic of my log when later today.
Old 10-24-2010, 11:03 AM
  #46
Z06supercharged
How much boost you running? And your iat's dont go over 75 on the rollers making a pull without meth? Man thats one helluva intercooler you must have on that setup!
I can start out a pull at 75 iat and its up to 120 10 seconds later with no meth. I need my IC in better airflow even tho my front plate area is open the IC isnt directly in front of it.
Old 10-24-2010, 06:15 PM
  #47
C5kid
C5kid's Avatar
St. Jude Donor '12
i stand corrected. my IAT went up to 75* on the way down to the dyno. it was alittle cooler out that morning on the ride down. These are the temps on the rollers.
13# of boost, the intercooler I picked up from Silicone Intakes dot com.
http://www.siliconeintakes.com/produ...3535f9c52cbb2c
Here is the proof. The temps that the dyno recorded.
And my IAT, that is even after we left off the pull.
Old 10-24-2010, 08:06 PM
  #48
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Congrats on getting it done man. You did an impressive job on it.
Old 10-25-2010, 08:01 AM
  #49
YeloFevr
YeloFevr's Avatar
There was a collective sigh when you didn't spin it the whole way on the first pull (<600whp)
Old 10-25-2010, 11:09 AM
  #50
Julian@Cartek
Julian@Cartek's Avatar
Congrats to see your beast on the road and running strong . Very nice for 3someC5 for giving you the HPE Flip-Drive! We are happy to see the HPE flip-drive has worked for you and solved you belt slippage issues while maintaining consistency at those boost levels. It’s nice to have that kind of a build and retain power steering as well as air conditioning. Can’t wait to see this car hit the track!
Julian Hormilla
(908) 317-4496
www.cartekracing.com
Old 10-27-2010, 02:43 PM
  #51
ZOHSIX
ZOHSIX's Avatar
Were you haveing belt slip before or after the flip drive? Was it caused by allignment of the flip drive?
Old 10-27-2010, 06:04 PM
  #52
C5kid
C5kid's Avatar
St. Jude Donor '12
having belt slip before the FD. Once installed I could tell right away it was making more boost. Just felt smoother.
Old 10-27-2010, 11:02 PM
  #53
easyvette
easyvette's Avatar
Julian Hormilla
(908) 317-4496
PFFFFFFFFFFFFFFFFFFtttttttttttttt This car dont go to the track but you can find it in Mexico. LMAO...
Old 04-29-2011, 05:45 PM
  #54
dykz34
dykz34's Avatar
Do you have any pics of the intercooler from underneath with the bumper installed? I'm curious how much area of the core is visible... thanks!
Old 04-30-2011, 11:39 AM
  #55
helga203
helga203's Avatar
What was your boost? What size pulleys?Stock dampener ?
Old 04-30-2011, 01:00 PM
  #56
C5kid
C5kid's Avatar
St. Jude Donor '12
with the P1, 3.0 headunit pulley and 7.5" ATI damper I was seeing 11-12#
Old 04-30-2011, 10:23 PM
  #57
dsmlights
dsmlights's Avatar
congrats on the numbers.
To My 347 build complete (56k=death)
Old 05-01-2011, 07:09 AM
  #58
C5kid
C5kid's Avatar
St. Jude Donor '12
those are old #'s. this thread is a year old, I hvae a F1 on there now
I dynoed the car it made the same power but w/ #3 less boost. So I pullied down and need to see what she can do back @ #12
Old 05-02-2011, 11:36 PM
  #59
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
Well git er done kid.
BTW the gold CCW's really set the car off. I like it!
Old 09-30-2011, 04:29 PM
  #60
C5kid
C5kid's Avatar
St. Jude Donor '12
BACK from the dead...
So this summer has been pretty ****** weather wise in my area, either raining, tornado's, earthquakes, floods, you name it we got hit.
Finally made it back on the dyno after fixing my fuel problem. And I am very pleased. There is probably a-little more in there but she got the official HOTROD stamp from MikeP.
Here are some specs..
NO METH
11.5 a/f wot
17* timing
75* IAT @ WOT
68* outside temp
Quick Reply: My 347 build complete (56k=death)
