LS6 Timing
Old Mar 11, 2010 | 09:54 PM
elite gm's Avatar
elite gm
Default LS6 Timing
Guys with boosted stock LS6's, how much timing are you running and at what boost? I am not interested in meth timing numbers.
Old Mar 12, 2010 | 10:29 AM
user_name's Avatar
user_name
I never bothered to not use meth. I'm running 17* at about 16psi.
The ls6's do not need as much timing as the ls1's when using the oem unported heads.
Old Mar 12, 2010 | 11:35 AM
Chris Stewart's Avatar
Chris Stewart
Interesting, I top out at 15 degrees with 13psi and I use meth. I guess you can call that a conservative tune.
Old Mar 12, 2010 | 02:21 PM
zee OH sex's Avatar
zee OH sex
how about guys running n2o on stock ls6. What kind of timing are you running in respect to your shot size?
Old Mar 12, 2010 | 03:51 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
A bone stock LS6 I would be in the 12-14 range to start with.. Some cars like 14 and some only like 12.. Each car to their own
Old Mar 12, 2010 | 04:24 PM
elite gm's Avatar
elite gm
Okay thats exactly where I have mine, and coming from ECS I am more comfortable with where I set it.
I have it ramping down as boost builds so it is approx:
3-4k: 17*
4-5k: 15*
5-6k: 14*
6k+: 12* (around 9psi with 3.8 pulley)
Old Mar 12, 2010 | 06:44 PM
Warp Factor's Avatar
Warp Factor
You might be able to push timing back up after the torque starts to drop.
To LS6 Timing
