Simple Crank Case Vent?
Old Mar 12, 2010 | 01:45 PM
IDM's Avatar
IDM
Default Simple Crank Case Vent?
I found this old post in my search.
Can I just do a breather filter where the oil cap is or do I need a check valve also and catch can? I'd rather just do the easiest effective thing as my engine bay is already complicated.
What kind of damage can not venting the crankcase pressure with FI do to an engine?
Beauty, so the McMaster Carr check valve (flowing towards the TB), and a Campbell Hausfield (sp) separator in line with the PCV valve and leave the valve cover vent going to the air filter like Andy says should do me pretty good right?
Quote:
Originally Posted by AMERICAN_HP
To answer your question Yes AND No....
Typically it is as easy as putting a catch can in-line of the PCV system. UNLESS you have F/I. Then its a little more complicated.
If you are running F/I you want to make sure that you arent only using your stock pcv valve. Cause if you are, the boost can/will overcome the valve and pressurize the crank case.
Most importantly I would install a check valve in line. This way you eliminate that problem.
Heres the link where you can get it. There are more than a few guys on here using this.
http://www.mcmaster.com/ This is the part number you want. "7775K53"
Other than this valve, all you really need to do is use a catch can. You will get a ton of guys telling you all of their "Super" pcv systems, with filters, adjustible vacum valves, electric solonoids, bla bla bla.... Just keep it simple and effective..
Old Mar 13, 2010 | 12:29 AM
IDM's Avatar
IDM
bump
Old Mar 13, 2010 | 11:05 AM
HP_Addict's Avatar
HP_Addict
if it were only that simple. you need a pcv system with catch can when hot in boost and a vented filter while in boost
not venting teh crankcase is not good for the engine
Old Mar 13, 2010 | 11:31 AM
IDM's Avatar
IDM
I realize that as I posted it but how so?
I noticed my oil filler reservoir was pushed up at the o ring.
Was thinking maybe that's due to too much pressure?
Old Mar 13, 2010 | 12:33 PM
corvettebob1's Avatar
corvettebob1
I set mine up this way in 2001 and still have it the same way and never had any issues with oil or pressurizing the crankcase.
Old Mar 13, 2010 | 03:42 PM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
My system is very simple and effective. Catch can check valve PVC delete.
Brian
Old Mar 13, 2010 | 04:26 PM
IDM's Avatar
IDM
so you removed the factory check valve thats all and added a catch can?
I wont be adding a catch can so I guess I cant do that
Old Mar 13, 2010 | 08:28 PM
HP_Addict's Avatar
HP_Addict
the gases will contaminate the oil and cause it to break down.
also increased pressure can cause you to blow the rear seal or as you have seen push the dip stick up.
I added a catch can and mcmaster carr check valve and then vented the valve cover.
Old Mar 14, 2010 | 09:41 PM
IDM's Avatar
IDM
Do you have any pics of your setup?
I'm trying to find a metal mesh style breather, not like the k&n material but metal so it doesnt get oil soaked.
Old Mar 14, 2010 | 09:46 PM
IDM's Avatar
IDM
I also do have a leak on my engine...maybe thats why
My dipstick didnt pop out but thats because the filler neck was popped off.
Old Mar 14, 2010 | 10:29 PM
HP_Addict's Avatar
HP_Addict
I got my breather from ECS. It uses a steel wool mesh prior to the filter.
Old Mar 21, 2010 | 08:45 PM
IDM's Avatar
IDM
Got the ECS breather and installed it.
70 bucks holy crap but it's a really nice piece
Can someone tell me exactly where to put the check valve and if I should leave the stock one or not?
Old Mar 22, 2010 | 11:58 AM
corvettebob1
Your check valve should be in the line right next to the port on the intake manifold.
If you have a PCV valve leave it in place, IT IS THE AIR METERING DEVICE.
If you look at the sketch I sent you it will show you where to place everything.
Old Mar 22, 2010 | 12:25 PM
IDM's Avatar
IDM
Bob can you dumb it down even further for me?
I wont be using a catch can so the diagram is confusing.
I just have the ecs vent so far everything else is stock...I do have the port on the TB capped as well.
is there a line in place already where I'll need to put the check valve?
Old Mar 22, 2010 | 03:22 PM
corvettebob1
Just cut into the line coming off the manifold and install the check valve.
Make sure to use clamps on the hose between the manifold and the check valve or it might pop off when under boost.
Ignore the catch can in the diagram and the rest of the system will be just like yours.
However I would highly recommend you rethink running w/o a catch can, if you open you throttle body and look inside with a flash light you will find oil puddled on the floor of the intake.
It's just waiting to get pushed into #7 & 8 cyl. breaking the top ring lands.
To Simple Crank Case Vent?
