Which Automatic Transmission?
Old Mar 23, 2010 | 09:01 PM
racerrob333's Avatar
racerrob333
My rpm trans held up great And I had several mid 9 passes on it put I have since went to the powerglide
Old Mar 24, 2010 | 10:04 PM
Rkreigh's Avatar
Rkreigh
480le, that said, you can build 2 465le tranny's and have change left over. if you are running street tires and limited drags, it will hold for a good long time
if you are much over 800, hooking it up will burn up the 465 eventually
the 480 is a pretty expensive mod..,
the power glide will definitely hold up and help you put the power down, but no OD so not as streetable for long trips & crooze
