Engine Knocking Noise
Old Mar 20, 2010 | 07:17 PM
The Yav's Avatar
The Yav
Default Engine Knocking Noise
I have a 00 vert with 50K miles and a Maggi M112, yesterday was driving took it up to 6500 RPM. Drove to work car ran normal, went to go home and the car has developed a severe knock, which goes away around 2500 RPM. Car idles fine, except for the knock vacumn, is at 12 inches, no anti freeze in the oil, did I spin a bearing? How about the Maggi internal bearings? Any constructive comments would be apprichated. Thanks
v/r
THEYAV
Old Mar 20, 2010 | 08:46 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Get an engine stethoscope for 15.00 at your local auto parts store and start poking around. If it gets worse under load (acceleration), you probably lost a rod bearing. How's your oil pressure? If it's low, just turn it off and tear it down.
Old Mar 20, 2010 | 09:06 PM
396375's Avatar
396375
St. Jude Donor '08-'09
I doen't know if you have a magnetic drain plug.If you do and you have spun a bearing there will be a lot debri on the end of the plug.You can also have your oil analized.Any large trucking company in your area will know where to send it.
Good luck.
Old Mar 23, 2010 | 07:53 AM
The Yav's Avatar
The Yav
Thanks Gentelman for your post,
Dodged a big bullet,,,,I went and bought a steth-a-scope, removed my left side coil cover (that's were the noise was comming from) and noticed the air pump hose was off and rattling against the frame rail.
Checking to see if I have a bad check valve,,,which created pressure.
I have got to say RPM has great buys on motors. My next project is to intall a one of his forged LSX next winter. I will be looking for advice on a LS6, LS2 or Stroker with my Maggi M112.
v/r
THEYAV
Old Mar 23, 2010 | 08:17 AM
BLOWNBLUEZ06
Wow! You have definitely defined "dodge a bullet".
Nice results.
To Engine Knocking Noise
