Alky pump problem
Old May 11, 2010 | 11:19 AM
mulalleybs's Avatar
mulalleybs
Default Alky pump problem
My alky pump hasn't been working for awhile now and I'm trying to figure out exactly whats wrong with it. When I turn the key to the "on" position you can hear the pump making its little whining noise, but when you step on it or push the test button the light stays red. I unhooked the nozzle to confirm that no meth was being pumped. Now when you hold the test button and slowly move the **** from 6 down to around 2 the light will turn green for a second then make a popping sound and cut off completely. If anyone has had this and knows the solution I'm all ears.
Thanks,
Brett
Old May 11, 2010 | 11:51 AM
corvettebob1's Avatar
corvettebob1
What kind of Alky system is it?
If it's Alky Control just call Julio he'll fix you up.
727-570-9999
Old May 11, 2010 | 02:18 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
727-570-9999
Old May 11, 2010 | 05:15 PM
joshtownsend's Avatar
joshtownsend
Sounds like the controller is the issue.
Old May 11, 2010 | 09:10 PM
mulalleybs's Avatar
mulalleybs
Ah sorry I wasn't more specific. Its the ecs alky kit.
Old May 12, 2010 | 06:12 AM
clif's Avatar
clif
St. Jude Donor '09-'10
My pump was doing something similar. My system in an Alky Controls system. I called Julio, and he had me pull a long bolt from the motor, to see if it was rusted. I did, and there was so much crud on the bolt, I knew the motor had gotten too much water in it and had seized up. I bought a new motor from Julio, and it came with a rubber cover. This new motor works great, and resists water!
Old May 12, 2010 | 08:42 AM
01z0666's Avatar
01z0666
julio is awesome...he knows these things like the back of his hand,great guy to deal with
Old May 13, 2010 | 06:56 PM
Julio's Avatar
Julio
727-570-9999
That number no workie since middle last year.
813-265-1400
Now.. other thing is your not suppossed to hear anything making sound when you turn the key ON. That means that the "turnon" setting has been set to low and the kit is activating under vacuum. So you need to open the controller and move that dial CW a little until it no longer makes any sound. There is an LED that shows when its activated or not. It needs to be off key on.
Call me and i'll walk you through the pump testing procedure.
Old May 14, 2010 | 09:42 AM
DOUG @ ECS's Avatar
DOUG @ ECS
813-265-1400
Aaaayyyye whata you know!!
Electrical guru, and great customer sevice!
Old May 17, 2010 | 11:54 AM
mulalleybs's Avatar
mulalleybs
813-265-1400
This includes the ECS alky pump system? That's the one I have.
Old May 17, 2010 | 12:03 PM
Julio's Avatar
Julio
Yes indeed
Old May 17, 2010 | 05:03 PM
mulalleybs's Avatar
mulalleybs
Yes indeed
Alright thanks, I will give you a call tomorrow when my GF isn't in town.
To Alky pump problem
