Fuel Problem
Old Jun 1, 2010 | 05:06 PM
ShockerRacing's Avatar
ShockerRacing
Default Fuel Problem
I have a 98 C5 Convertible with a forged bottom end/AFR Heads/Cam/78mm FAST/Procharger P1sc. It runs at 60psi fuel pressure but when I go full throttle the fuel pressure drops to about 40. I have a new Racetronix Fuel Pump and 60lb injectors but the car does not have a Boost A Pump. I was starting to think maybe I need one but when I was looking at MSD's website I noticed it said "NOTE: Not for use on Pulse Width Modulated EFI systems (no return line)" mine is a 98 so I do have the return line. Does this mean that I can't use a Boost A Pump? If so, what else should I check? I have already replace the fuel filter.
Old Jun 2, 2010 | 05:00 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
You can use a BAP on your car.
You may also consider a dual in-tank system.
Old Jun 2, 2010 | 07:05 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You might also look into RACETRONIX Hotwire Kit for the Fuel Pump and definetely the BAP, use a KB it is good.
I have a '98 too and I have no fueling issues.
Make sure you are not also getting belt slip, if you are then you voltage will be dropping to the pump.
Thanks,Matt
Old Jun 2, 2010 | 12:18 PM
ShockerRacing
Matt, you have a 98 with the return fuel lines and you are using a BAP?
Old Jun 2, 2010 | 01:15 PM
Will at RSI's Avatar
0Will at RSI
Former Vendor
Check out our Dual Hanger sale!
http://forums.corvetteforum.com/c5-f...-blow-out.html
Old Jun 2, 2010 | 05:46 PM
madmatt9471
Yes! I have the RACETRONIX LPE Pump, RACETRONIX Hotwire Fuel Pump Harness, and a MAGNAVOLT BAP, 80 lb SIEMEN DEKA Injectors and ALKY Control Meth Kit (For safety)
Plenty of fuel and "O" drop in pressure
Thanks,matt
Old Jun 3, 2010 | 11:00 AM
ShockerRacing
Thanks for the info Matt!
Old Jun 3, 2010 | 11:37 PM
madmatt9471
You're welcome
Thanks,Matt
Old Jun 4, 2010 | 03:36 AM
SBCGENII's Avatar
SBCGENII
what rpm does your fuel pressure drop?
Old Jun 4, 2010 | 03:18 PM
ShockerRacing
Anytime I go full throttle!
To Fuel Problem
